Hey, i bought a R34 GT-T about a year ago and would strongly recommend you look at one of them before you buy a r33. There is nothing wrong with R33's, but you cant beat the look of the R34. Not only that the R34's have a revised engine that has more power and they also have tracktion control which is a great thing for chicks in the wet. Im not sure excaly what models have traction control but mine is a 98 R34 GT-T series 1 - 5 speed manual 2 door coupe. And i know you can get them with a sunroof too.
Well, after looking at numerous skylines, for some reason I prefer the look of the R33. I have no idea why, it's just the R33 is more appealing to me. I still like the look of the R34, both are nice looking cars exterior wise, but I'd just rather the R33. As for traction control, I couldn't really careless to be honest. My XU6 doesn't have traction control and I can throw that round corners quite well in the wet.... For a chick.:(
Edited by Manda2365
It's supposed to work at various speeds and only kick in when loss of traction is detected, as is my understanding. Maybe others can also confirm this?
Nope, if you read the image you posted it actually says that it's "varying the angle of the rear wheels in relation to those up front" and "sensing vehicle speed and your rate of turn"...
HICAS still works in GTS-T's without ABS or G sensors so there is no way for the HICAS system to detect traction loss. Its simply calculated on the front steering angle VS vehicle speed VS steering rate of turn.
It usually only works over 80km/h.
It's definitely not a parking aid, how can it be when the rear wheels only vary by one degree? Someone might be thinking of the old preludes: http://au.youtube.com/watch?v=b0sVD17WSdQ
^Ah I see makes sense Thanks :)
regarding the 1 degree, like I said only what I've read here. Some other websites I've came across seem to have confirmed this. I might be able to find some later, cheers
You may be in luck Amanda,
There's an R32 GT-R being prepped for sale at Top Secret Imports here in Blacktown, Sydney ATM.
It has done only 80,000Kms and the interior is absolutely like new!
Your budget is $20K and so is this. No modifications except for Susp'n/Springs & exhaust.
I came across it to-day and it has no rust whatsoever.
And I have no connection with that company.
Hope this helps...
Tez
  • 1 month later...
Hey Guys...
It's been awhile since I last posted in this as I was on holiday in Tassie when I started the thread and the Skyline I had my eye on was sold before I got a chance to look at it. So I'd put off the search for a Skyline as there wasn't much else that caught my eye. Until now....
Another one has come up for sale. Same deal...1995 GTS-T, White, Sunroof yada yada...
It looks to be for sale at the same place as the other one, and I'm almost convinced it's the same car. Only it's 2k cheaper. Should I be worried about that? It's advertised for roughly $9k + on-roads. Is that too cheap? Should I be a bit iffy about it? Also, if it is the same car, I guess I should be concerned as to why it's for sale again a month later at a cheaper price, yeah?
IF its the same car.. just means it might not be selling.. enquire as to whether its the same car and why the price was lowered.. for 9K i'd be concerned that it may not be in top cond. but that could be anything.. get a mechanic (racv is good for victoria) and get a full test done.. just go over it with a fine toothpick and magnifying glass and be happy that its not a dud before you buy
I was under the impression hicas only kicks in above 70kph anyway?..
Its a weird feeling but ive never really had an issue with it..
Been a skyline driver for 2 years now.. and its fantastic..
1997 R33 GTSt Series 2..
You shouldn't be paying anymore than $12K for a good condition R33 Series 2.. people advertising over this are dreamers..
Mine is in perfect condition except for the gearbox needing some attention and i wouldnt expect over $9k if i sold it..
$12k for a good condition R33 Series II? In Adelaide here its about $12k for a good condition Series 1!
At $20k I'd be looking to spend it on an R34 GTT or late model R33 Series II and splash a few bucks on it.
If you know the VIN, put it in here:
http://raws.dotars.gov.au/rawswebpublic/RAWPubVehSearch.asp
and you can see who imported/complied it. Do some research as that could give you a clue as to what type of cars they bring in.
Feel free to cruise by our showroom, we've got an R33 Series II and R34's in stock now.
cheers,
David @ Carizma
Thanks for that, that's great information. The one I'm looking at is unmodified and according to the website it's recently imported from Japan, not yet registered here. It looks untouched from the photos, the only mod I can see so far is the exhaust.
As for the 4-wheel steering, after learning from you guys that it doesn't affect day to day driving, I'm not worried about it. I'm not exactly the type to be flinging it sideways at every corner. >_< And like I've been informed that if I really don't like it, I can get the lock-bar? put it in and it'll be like it was never there....I hope.
What's the deal with imports being registered? Is there any chance I could end up with something dodgy, compliance wise? Is there any way I check things like that?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
