R32 GTR engine for sale (was imported from japan to use in project that never took place)
Rb26 Bottom end bored out to rb27, ceramic & teflon coated pistons, t51r HKS turbo with custom low mount cast iron manifold,.70 - 10.3 Cams (Big Cams),Jun Cam Gears
has 1 cracked piston
suit someone chasing horsepower
Prices -
Head - $2000
Bottom End - $2000
T51r, with custom manifold and bov - $3000
Front Assembly - $500
Rear Diff cradle/ everything - $1500
Most of the parts are at Canak Autosports in Penrith NSW and can be viewed by appointment only, if someone would like to buy more than one item a package price can be arranged any enquires pm or use this thread if you wish to make an appointment to see the parts call 0432344785,
A low mount t51r? Yes, pics please
Also specs on the bottom end? Stroker crank to 2.7 or stock crank and oversize pistons? Oil pump? R32 or R33 motor? Rods?
Cheers
Cheers
will update the info you asked about for you tomorrow just want to double check with my mechanic to make sure
regards
jeremy
i didn't know how to edit the original post so if one of the mods can make this the edited version of the original post would be appreciated..
Rb26 Bottom end bored out to rb27, ceramic & teflon coated pistons, t51r HKS turbo with HKS low mount cast iron manifold,.70 - 10.3 Cams (Big Cams),Jun Cam Gears
engine is complete but in peices from when it was stripped down and inspected
has 1 slightly damadged piston (fixable) but mechanics opinion is to replace
Prices -
Head - $2000
Bottom End - $2000
T51r, with HKS cast iron manifold and bov/wastegate - $3000
Sump - $500
Triple Plate clutch & flywheel (pretty sure os giken item but not 100 percent) - $1000
GTR r32 Gearbox (has been pulled apart and inspected good work condition) - $1500
also have a standard rb20 twin cam head - $500
post-28922-1225063734_thumb.jpg post-28922-1225063752_thumb.jpg post-28922-1225063773_thumb.jpg post-28922-1225063790_thumb.jpg post-28922-1225063806_thumb.jpg post-28922-1225063822_thumb.jpg post-28922-1225064139_thumb.jpg post-28922-1225064162_thumb.jpgpost-28922-1225064184_thumb.jpg post-28922-1225064205_thumb.jpg post-28922-1225064227_thumb.jpg post-28922-1225064245_thumb.jpg post-28922-1225064263_thumb.jpg
Cheers
pics are up...
bottom end has a stock crank and oversized pistons, standard nissan oil pump, r32 motor, standard nissan rods
I thought the T51R had Vband section for the turbine in and out?
Or is it the Garrett version?
it is the garret version, and in regards to your earlier question about selling the wastegate, will only sell as a package
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
