Just do a search. You will see only a couple of people have been hapy with hi-flowed injectors and they got them from the States, I beleve it was from Deutch works or something like that. Do your self a favour and don't do it or you will forever be wandering if they will fail. For $700 just get the Nengun Nismo or Performancewise or Slide injectors. Sard or Nismo doesn't matter but just don't buy hi-flows. From personal experience over two years I could not get a proper tune and was always down on power til I got rid of my hi-flowed injectors then gained 20kws just like that. The difference in driving was much better and a feeling of confidence in the reliability is much better. If you really have to buy them then do a search and you will find them.
^ hmm $$$ dont justify for new sard/nismo injectors at this stage.
BUT with your response to my other thread it looks like i wont have to upgrade considering the GTT injectors hold around 230~rwkw
thanks for the prompt reply :P
