Hi, I've got a 1994 R33 NA and am wondering what 4 stud wheels fit, I have found a set but am unsure if they will fit properly. The wheels I found are 17 X 7.5 Wheels 4x114.3 +47. Would they fit straight on? Before anyone says try them on, I'm looking to buy these interstate. Cheers.
Edited by Ten Four
https://www.sau.com.au/forums/topic/241665-r33-na-4-stud-wheel-question/
Alright cheers, does that mean they will look weird? How would they look in comparison to stock 4 stud wheels? I don't have a kit or anything. Spacers, would they work and what would I need?
Edited by Ten Four
Well if the offset on an n/a is the same as the turbo it is +48 (??), other words the rims you want to buy will sit 1mm further out from the guards than the wheels u have now. Preffered offset for an r33 is +30 cuz it sits nice and flush with the guards.
tbh id look elsewhere. itsa good buy but would be shit on your car. i run 18x8 with +38 offset and its sits real nice. so anything around that ballpark figure is what you want. anythingx8 with +30 to +38 would look nice, 7.5 is just too skinny for an R33 imo tho. moar grip = win :P
Edited by G0DZLR
Silly NA's, just when you thought you found something.... The hardest part is finding wheels that actually fit, then theres the part where they have to look decent without costing a fortune, its impossible, impossible!
Edited by Ten Four
anyone know how will 18x7.5 rims with a 45 offset look??
finding it very hard to find rims, and found a cheap pair with those specs ^
Can anyone give me some advice where i can find rims plus tyres(dont mind if new) for under 800
theyd sit too far in the guards i think. i have 18x8 with +38 offset and theyre just in the guards by about a mil.. look awesome tho
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
