Hey all,
Couple of months ago, i had my car dyno'd and got around 157.3kw atw, with afr around the 11-12 mark.
Mods;
- batmbl front/dump
- xforce hiflow cat
- apexi catback
- ARC 110mm SMIC
- Standard boost - leaking to about 12.5psi~
- Splitfire coilpacks
(here is a dyno scan of 150.3kw, dont have a copy of the 157.3kw run which included a new dump/front + cat)
Had another dyno run today at Swinburn Tafe and confused about the results..
*note; when the car was on the rollers, it was vibrating real badly too, he suggested it may have not been tied down properly or something..
The differences between last dyno and this one;
- New O2 sensor
- Installed a socket into my ecu for future remapping. (Standard chip in ecu, just installed a socket and plugged standard chip back into ecu)
For the past 2 years all my dyno runs have had an AFR reading of 11-12..
Why has it dropped all the way down to 10 resulting in a large loss of power :P
Thanks
Patrick
https://www.sau.com.au/forums/topic/241685-afr-down-to-101/
If the ecu detected knkock, then it would have reverted to the low octane map, which i richer. Have you tried resetting the scu?
hmm you could be onto something.
It could be a result to the problem with my car.
http://www.skylinesaustralia.com/forums/Lu...90#entry4195890
As the car was left to idle before it got onto the dyno it was starting to miss, guess it might have been on safe map as it was run on the dyno?
https://www.sau.com.au/forums/topic/241685-afr-down-to-101/#findComment-4217654
Probaly your o2 sensor that needs replacing. Check with datascan/consult for fluctuations in o2 readings. When o2's stop working properly the ecu reverts to a safety map and dumps more fuel.
yeah im thinking its my o2 sensor.
When i rev in neutral the o2 voltage doesnt fluctuate. It just stays at a constant voltage.
Although ive heard that o2 sensor doesnt affect the car on full throttle so wouldnt make it run rich?
I'll get the o2 sensor replaced anyways, cause its the only thing which has been changed since last dyno...
https://www.sau.com.au/forums/topic/241685-afr-down-to-101/#findComment-4218012
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
    • Just one thing; tapping tapered threads is tricky. Taps are always tapered and you would generally run it as far as you can, but with a tapered thread you have to stop much sooner otherwise the wide part of the taper will run in too far and you will have to thread the sensor in too far too as well (possible that it will never make a good seal) BTW nice wide wheels, I guess the top one is for the back!
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity. Edit: 11kg each (or 10.9/11.1 depending on what my scale decides over multiple tests, the 18x11 don't seem to weigh noticeably any more than 10.5)
