Just need some advice on cutting about 10mm off the bottom of my bike's fender without destroying the paint with excessive heat.
It constantly bottoms out going down kerbs and needs a trim.......where it's marked roughly with a silver marker.
I originally used a small angle grinder with a 1mm disc to cut & shape the fender then a dremmel to clean it up..........but that was before paint.
The black will be easy to fix, but I don't want heat to lift the airbrushed stuff.
https://www.sau.com.au/forums/topic/241755-help-on-how-to-cut-a-bike-fender/
deffently take it to a pro pete. then if something goes wrong youve got someone else to blame :rofl:
only way i can think of though that would get you a decent finish would be the angle grinder. maybe do a few seconds of grinding and dip it in water to get it cool to try and save the paint? theres not a whole lot to cut off so you might get away with it? also try calling someone like 69 customs, they might be able to give you some pointers on cutting airbrushed things?
but really, i wouldnt go off something i or anyone off here says. id really go to someone whos done this before haha :D
If you do it bit by bit with a 1mm disc on an angle grinder you shouldn't damage it too much (the heat will want to stay in the smaller end anyway). Having said that I'm pretty sure you would need to get some of the air brush touched up. I'm a fourth year metal fabricator and have cut a bit of powder coated/ two pack stuff but never any airbrush..
PM Craved (you will find him in the fabrication section), he seems to be a wealth of knowledge.
Pete,
Ive done this kinda work before ... many years ago.
Mask up the line you want to cut along, then mark it up with a texta. Find the finest, finest cutting tool you can (maybe in your case a fine cutting blade on a grinder and/or dremel). Peal off the tape when you are done as soon as you can, because water and masking tape can leave the tape glue behind (and some of the paper). You will more than likely require a small touch up around the cutting edge.
:rofl:
If you need a good bloke for the touch up ... try Daniel Stone Paint and Panel at Hackham. He's an old riding buddy of mine and hes done work to my Stageas. He's done body work for custom Harleys as well as jap crap bikes :D Tell him ruby sent you and hell look after you.
Edited by RubyRS4
yeah touch up of the edge after I can handle cause it'll be in the black area.......as long as the heat doesn't lift the paint further into the airbrush area I reckon I should be OK..........I hope :rofl:
yeah touch up of the edge after I can handle cause it'll be in the black area.......as long as the heat doesn't lift the paint further into the airbrush area I reckon I should be OK..........I hope :D
You'll be fine then.
Use the tape to eliminate any potnetial chipping or burring of the paint.
Use the finest cutting edge/blade you can and take your time. It is a piece of cake.
:rofl:
If you need a good bloke for the touch up ... try Daniel Stone Paint and Panel at Hackham. He's an old riding buddy of mine and hes done work to my Stageas. He's done body work for custom Harleys as well as jap crap bikes :( Tell him ruby sent you and hell look after you.
+1 he did the paint on my GTR rims.
Maybe try and run some water over it when your making the cut with a grinder it will help keep the metal nice and cool while cutting.
If you want to be sure not to lift the paint, use a file.
Sure it will take a while but there will be no heat buildup, and if you file from the paint side (apply tape along the finish line to protect from acidents/mistakes) into the fender you should have minimal paint damage.
alright pete i didn't read all of this post but mut some masking tape on the fender draw your line on top of the tape and cut it with the 1mm disc just let it cool a bit before cutting all the way through, ive seen it done and its worked but yeah you might want to go and see a professional good luck either way.
cheers... michael
I wonder how a tungsten bit on the die grinder would go?
That's what I would go with. Perhaps try and use an air hacksaw for the bulk of it (minimal heat) then u could just die grind it for a smooth finish....
Troy from Nightmare Designs is giving me a hand to cut it with a paper thin disc and running water tomorrow.
Check out his website and see if you recognize any bikes..........he's been crowned the best bike painter in the country in 2007 at the nationals (Bike Week) on the Gold Coast.
yeah I might even stick a wet sponge underneath as I'm cutting........any volunteers to hold the sponge :)
Just take it easy pete,slowly is always the key,you know bikes are like woman,like roo said mark up with tape etc,use smallest blade possible and just go slow,it wont heat up that much then,need a hand let me know
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
