I want to buy a alloy radiator
Problem is i need a r32 radiator as that is the car and i need the mounts to line up but will the hoses line up on a rb25det?
Basically i need one but need to know if i can use a r32 one on a rb25det engine or if i need different hoses etc.
ALso what kind of Thermo fans are you all using. I really need to sort this over heating issues out bare in mind i am in Darwin and the temps up here are around 36 most days with around 80% humidity. it gets hot and my engine hit 105degrees alot.
Any suggestions would be great
https://www.sau.com.au/forums/topic/241900-cooling-issues/
the RB series radiators outlets are the same if not very similar
i would get the R32 one and if you have an issue with hoses make something up to fit (its a very simple job)
ill see if i can find the fans and take a pic for you
https://www.sau.com.au/forums/topic/241900-cooling-issues/#findComment-4220699
yeah those fans are nice, i would love to install some but my car stays cool enough,
as your in darwin aswell, i would suggest your get a 19row oil cooler, it will drop your water temp 10 degrees :)
so that and a alloy radiator should drop your water temp down below 85
https://www.sau.com.au/forums/topic/241900-cooling-issues/#findComment-4221053
If your interested I brought a set of el i think ford fans same twin thermo setup but couldnt get em to fit in my gtr with minor trimming they would have fit a 32 radiator okay just wouldnt clear the power steering
Am in darwin and could probly yank the radiator too if ya were keen to check one out as motor is coming out anyway
In darwin so pm if ya wanna look reckon there was an alloy 32 radiator on boostcruising Darwin section recently it mighta sold already though
https://www.sau.com.au/forums/topic/241900-cooling-issues/#findComment-4221111
