hey all got a few parts here that needs to go
all parts are located in SA, prefer pick up only or post within SA only
HKS 2540
very good condition, has a garret compressor housing
to suit RB20/25
asking $900
R32 Greddy Type S coilovers
excellent condition only done 1500km on these, comes with C spanners
asking $1450
RB20DET
engine has done 158,000km always serviced with motul oils and fluids
comes with loom and computer, has braided oil and coolant lines, minus turbo (can arrange standard turbo for extra $) price has been adjusted to suit
asking $1300
RB20 Gearbox
good condition, hasnt been treated harsh rear main seal done about 5000km ago
asking $450
Genuine GTR front bar and front guards
R32 GTR front bar genuine plastic item in painted matte black, good condition $300
R32 GTR front guards, alright condition, very light weight compared to GTST guards $350
can call/sms me on 0431171992
pics will be up on other items tomorrrow
https://www.sau.com.au/forums/topic/241902-r32-parts/
what engine was the turbo on?
how much power was it making?
when did it hit boost?
how many k's old?
cheers
hey mate the turbo was on a rb20 and it made 200kw on morpowa's dyno running 1 bar boost, wasn't running bigger injectors and only a FMIC and 3inch exhaust
its been a while since i drove the car soo i would say it hit full boost at around 3500-800
the turbo was second hand when i bought it and since i had it has done about 10,000km
https://www.sau.com.au/forums/topic/241902-r32-parts/#findComment-4222319
Hey man you wouldnt sell those coolant and oil lines would you?
Im after some RB20 parts,
* turbo coolant line that goes around the head.
*ECU temp sender, big yellow one
*turbo to mani nuts
https://www.sau.com.au/forums/topic/241902-r32-parts/#findComment-4231227
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
