I like all Skylines but I feel a bit of vomit come to my mouth when they're over dressed & and turned into rice pudding...........Chad's is a good example of what clean & tuff should look like.
Remember, less is more folks.........Japs knew what they were doing with the original design, why go & stuff it up?! :D
Thanks Pete :) I love the look of your car as well, i've never been a fan of over the top kits, standard body with minor changes FTW!!! Im just not a big fan of people who drive skyline just to be cool :D
  • Replies 157
I find R32 owners are the arrogant one thinking that their R32 is the best thing EVER to come out of japan and every other model Skyline is rubbish - those people needs a punch in the face, especially those with GTSt's thinking that.
LOL agree
i find it hard to make any skyline freinds whislt driving
they look dead ahead and don respond to my freindly beep and wave
could be due to looking like a rapist?.
We are much friendlier down here in A-holetown
I take a squiz at any Skyline. Just because I own a GTR I don't think I'm king of GTS-t's...
well said i love anything with an rb even a vl.... i try to appreciate everyones skylines for what they are and after recent events i even have huge appreciation for the humble 180 sx. try to wave to most line drivers if they are giving eye contact and look friendly
We are SUPERIOR... simple!! ... and we know it. :(
Don't flame me I'm kidding!
I reckon my old GTS-t was one of the best rides I have ever owned.
Respect to any tidy ' line....You give me a wave you will get one back.
Crap you are so up yourself :D
I smile and nod to pretty much most skylines / pintara's I see (lol, the pintara turbo wagon, nice), fingure up in wave salute, but dont "wave" away as such
as for arrogance, I love MY rbdet, but appreciate others whether they be 2litre, 2.5~.6, or 3litre
You girls all better be waving to me when the N1 finally hits the streets. I don't usually go out of my way to get too freaked out when I see a decent import - a nod or a small wave is enough to acknowledge good taste.
What I often find is that some people are intimidated by the "legend of the GT-R" - old people think you're a hoon, GTS-t drivers think you reckon you're better than them and snob them off, Commodore/Falcon owners think you drive around just looking for runs etc etc
Then again, I'm old and married, so I don't feel any particular urge to impress people on the streets either lol
lol i reckon i used to more looks in my 327 lj torana than i do in my skyline
i had a nice original torana for a long time.... i brought it from my wifes granddad... i almost regret selling it :D
you get more ppl looking at the classics thats for sure :(
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
