  • Replies 402
Posted Images
ok so im not coming tonight. Lost double episode season finale is being downloaded....... :)
Bwahahaha! Lost!!
So I guess you are just watching it because you have invested all those years in it thus far?
I have a family member with the same addiction.
She doesn't want to watch it, but she also doesn't want to "throw away" the past however many years.
Pffft, watch it tomorrow at work in the time you'd usually spend here or on FB.
FB? :D
nah.....wife going out...have to babysit....raincheck for next week me thinks....I tried!
+1 for this comment lol!....I thought he worked for SAU!
I should talk!!! :D
Bwahahaha! Lost!!
FB? :D
I used to watch it quite a bit, then started missing episodes due to their bloody inconsistent times (stupid TV networks can't make a decision about when they'll run it, and stick to that decision), so I couldn't follow the story. I'd still like to catch up with it where I left off.
FB = Facebook.
nah i cant get on FB at work anymore, and i sneakily get on here during the day lol
so cant watch it at work either :D
i love the show, plus my uncle is one of the directors so there is a family connection..........
sorry but TV wins this time lol
I'm out unless I get the R31 started lol.
The Stagea is now nearing time for a service but there are some parts I need to get ordered in to be fitted whilst it's there.
If I don't make it this week I will bring the 31 next week, it needs a good run.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
