  • Replies 402
Posted Images
  • 6 months later...
Sorry bout the noon question. But where u going? Truckstop... I take it you mean one at the start of the old pacific highway. If so I'm interested. I haven't taken mine on long run for months...
Yep, meet at the truck stop, then you can decide if you want to go the Pac Hwy, or the F3 to Gosford- then meet up with another group up the coast.
about 7:30ish for a 8pm depart.
Man up Iain... its only a little coolant. :D
hahah ive taken it there before, got too many laughs :D
if im free this week ill come up in that! assuming GIO transferred over the green slip stuff to the RTA. had to call them because it had not happened since saturday
Timing is perfect. Rare 3 days off. Might even try putting the tv tuner in. I only had it on shelf for like months now. Also will get a second opinion on the fart sound the engine makes sometimes when boosting sometimes.
Do a search on the "farting" noise, I'm sure Spoolin'12 had a buggered BOV, might be a place to start.
ok, was thinking BOV, couse when its in high rpm it happens and if you dont back off you can keep the fart noise for a few seconds, then once you back off its gone.
will be there on thrusday, be good so see a few other stagea's lol
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
