Zu-Tsu-tsu-tsu-tsu-tsu.
It goes by a variety of names. Flutter (mostly used by import drivers), dose (VL Turbo drivers of the world, unite), "pigeon sound" (uninitiated).
Block off the blow-off valve, and read the dose bible for extra hecticity. Google for VL and Dose to find lots of videos.
The main thing that separates dose from flutter is that guys will modify their inlet piping specifically for the sound.
Edited by scathing
