after a lot of talking and reading i have changed my mind from gtss turbos to Garrett 2860R-5.....
i will have all the surport mods sorted! its a built motor to....
i have been told they will come with gaskits ect but what needs to be modified to fit them just the oil return line? do i need a oil restrictor in the line going to the turbos?
any advice would be great!!!!
this is for a r32 gtr also
thanks in advance steve
https://www.sau.com.au/forums/topic/243305-garrett-2860r-5/
ported head matched manifolds
jun guilds stano vavles
stock cams
stock cam gears and springs
baffled sump oil restrictors in the block cam cover plates
jun collar and oil pump
acl race bears mains and big ends
rev rods
cp pistions
1.3mm metal head gaskit
metal inlet manifold gaskits
pfc
stock cooler
stock inj stock fuel pump
stock air flow meters
stock dump pipes
front pipes 3 inch cat 3inch exhuast and cannon
stock turbos
os giken twin plate clutch
eboost 2 set to 13psi
262rwkw 351hp
i also have sard 720cc inj now and a sard pump and greedy hard pipe kit is on the way.... i will also be getting nismo afm
https://www.sau.com.au/forums/topic/243305-garrett-2860r-5/#findComment-4240593
so did you just use the stock gaskits? new ones of course.....
pritty much.. they came with my tomei gasket kit as i did head gasket at the same time aswell as a couple other things
nice list of parts, you'll need afm's aswell if your goin the -5's, either nismo's or Z32's
https://www.sau.com.au/forums/topic/243305-garrett-2860r-5/#findComment-4240622
    • The title should have posted "EFR7670 exhaust housing selection RB26" I can seem to edit thr title on my Android.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
