hi there guys i bought a 96 s2 skyline coupe to go drifting with...........we never got it done
ive been left with a car that i cant do much with so im wrecking all the parts plus some
extras......im not up all the parts names and how to sell them so pls give me some slack!!!
I will add more parts and photos asap
THINKING OF DOING FRONT AND REAR CUTS DEPENDS ON INTEREST
PARTS LIST
Complete engine with all the bits $2500
Manual gearbox $1500
LHF Guard $150
LHS Complete Door $450
LH Driving Light $200
RH Driving Light $200
RH Headlight $380
LHF Seat $100
Rear Seats $100
Steering Wheels(i have 3 oem) $200ea
As i said if never done this before so lets see how it goes
All series 2 parts avail so pm me if i can help with anything
https://www.sau.com.au/forums/topic/243479-r33-s2-parts-for-sale/
PARTS LIST
LHF Guard $150
RH Headlight $380
LHF Seat $100
Rear Seats $100
Where you located??
hey, is it ok to pop up saturday?. if its all ok with the gear suround, plastic drivers side switch suround and all.?. thanx
not sure if you pmed me, but i didnt get any messages..
sweet, how much for the plastic gear suround and the plastic drivers side window soround. can u pm me your address and a good time to pop over.. thanx :banana:
sorry but im not to sure how much if u wanna let me know how much u think i will
look at yr offer
hey, i think ill pass on your parts.. ived contacted you to many times and still no prive or answers, and i was going to spend a fair bit of cash for reconditioning my car. But i guess you dont want the business?.. all good, i found another series2 for parts...
Hi mate, just need the wiring loom that goes from the back of the motor into all the coilpacks, you should be able to just unplug it all. it's not long, about 50cm long with one big plug on one end and six smaller plugs for each coilpack. Let me know if you have it. I guess about $20 posted to Sydney. They're not expensive from Nissan but thought I would try and get it off the forum first.
Cheers
Ben
hey mate ive been busy sorry for this
if u still need some help let me know im home
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
