hey guys, my car is going back to sam next week for the last bits and pieces to be done on the engine, of which includes an exhaust cam gear. while doing it I was thinking he could maybe replace my stock cam gear cover with one of those clear cam gear covers off just jap, but I got a few ques...
1. will it fit an rb25? - if not can you get some? where?
2. is the quality decent?
3. are they legal? or can they melt and your engine goes boom, catches on fire, kills you while you drive into an orphange?
soz... but cops defected my old oil based pod once because they said it could "catch on fire" :thumbsup:
any experiences with them would be great too!
Thanks,
Adam
https://www.sau.com.au/forums/topic/243520-justjap-clear-rb26-covers/
soz... but cops defected my old oil based pod once because they said it could "catch on fire" :bunny:
Thanks,
Adam
My understanding is you need a RB26 backing plate for em. Standard is plastic but just black so no change there only rice factor baby so go for it :blink:
Oil based pods change emissions in some small way & thats why that cop incident happened, get a 3A dry type and you will be sweet. see DR DRIFT
Plus the oil coates things like AF meter and thats not good as well as forming deposits in intake pipes and coating turbine blades. :)
Plus the oil coates things like AF meter and thats not good as well as forming deposits in intake pipes and coating turbine blades. :bunny:
Cheers mate,
done everything you said a long time ago :) apart from getting a clear plastic cover... which imo doesnt look ricey...
then again, to each his own...
soz... but cops defected my old oil based pod once because they said it could "catch on fire" :/
Thanks,
Adam
The RB26 clear cam gear cover WILL NOT fit the RB25 because the RB25 has the variable timing buldge in the front of the inlet cam. However, there are clear covers available for the RB25, you'll find it if you look hard enough - hint, look at some overseas site, perhaps Ebay in the USA or Yahoo in Japan.
I dont think there would be any problems with installing the clear timing cover in terms of the law. Also, in regards to your pod cover, all you needed to keep it legal is to install some form of a shield or a 'box' with a duct feeding fresh air into it.
Hope that helps.
G'day Adam,
PSI Parts sell clear cam cover for RB25 - http://www.psiparts.com.au/front.asp?pid=28 - was thinking of doing it myself.
Not sure about the quality, you could ask them to test fit for you?
Cheers
Grant
soz... but cops defected my old oil based pod once because they said it could "catch on fire" :D
Thanks,
Adam
The Clear RB26 covers that Just Jap sells are a Genuine Trust Product.
They also sell Clear Covers for RB25 made by PSI, however they are hardly comparable to the Trust RB26 type, and are only made from very thin plastic.
Your right, they aren't comparable as one is made using plastic injection moulding, the other vacuum moulding. As for the thickness, well I don't want to get into the design specifics as that in itself took several months. Suffice to say we have sold about 150 of these both here and overseas. :P
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
