1992 GTST,
Overall good condition, though with side accident damage.
The damage is not a great deal. Quoted round 750 to fix the drivers hand side, that includes pannel work, skirt, and respray of the entire drivers hand side.
Briefly, taxi sideswipped me in an effort to pickup a passanger and took me to the gutter.
Power everything + sunroof
Mods.
EBC greenstuff pads,
Just flushed with Castol Gp600 from RaceBrakes
Dunlop fm901s on the back
Goodyear ds-g3 on the front
9puck brass/organic clutch/lightened flywheel
Whiteline front strut bar
King springs
Koni yellowsport shocks
camber kit
Whiteline sway bars
adjustable caster arms
bosch 040 intank fuel pump
Turbosmart in cabin dual boost controler
Apexi pod filter
Apexi boost gague
rspec turbo timer
3" exhaust from the turbo
Custom oil catch can
belts/water pump done at 95k.
Alternator just reconditioned
New GTR Radiator + r33 fan
Idlers replaced, fan hub replaced.
Leather boots
20% Tints
Remapped ECU on the dyno
Fitted with 2 highend alarms including tracking.
11 months rego.
Also fitted with a highend sound system with sound deadening, most likely will be removed if the buyer is not interested.
Please PM or post.
Pics of damage below.
Serious offers are open/neg
https://www.sau.com.au/forums/topic/24358-r32-gtst/
    • Ok so will run the piping over that radiator and no plenum it is. Put that money towards a Haltech and see what suits. Any ideas something like an elite 2000 or 2500 right? My long term goal is 300kw e85 and manual swap and that’s a dream come true. For now will be 200kw and auto the stock rb25det neo intake isn’t too expensive with throttle body. If I was to have the port matching done, Would that be better than the stock de intake as the det has bigger holes plus has the spots for sensors etc? And suit more long term?  appreciate the advice?
    • You understand AFR is not the only thing that contributes to it pinging yeah? Funnily, what the AFR gauge will tell you when it likely is pinging, is going to make you think things are really safe and good.
    • Run the piping how we all have for decades. Also the duel runners with the +T setup dramatically helps it gets on boost quicker. Yes, chase huge power it'll become a problem, but you're a long way off when you're already saying an aftermarket ECU is out of the budget. You also say NisTune as it's simple, and then immediately say it'll be painful, meaning... It won't be simple. It will likely cost you a lot more stuffing around with a Nistune, than just putting a Haltech or similar in.
    • I’ll order an afr gauge to keep an eye on it.  Then will get a haltech soon
    • TD05 or maybe pulsar PSR2867r Gen 2?  id love a garret but it’s quite out the budget for now and I’m not chasing crazy power.    yeh fuel pump haven’t looked into but whatever works, kind of last on my list.    Nistune because it’s simple but Ik it’s a lot of pain especially as I’m auto +t with the whole seperate TCM etc still investigating that. Haltech id love but once budget tight for now atleast.    finally the reason I’m trying for a plenum instead of the stock intake is I already have a standard Intercooler mounted etc. so the ports are on both sides so trying to not have to go over the clutch fan radiator etc. trying to find a good deal return flow if I don’t than this will do for now I guess. btw any ideas with that, apparently some people have to cut blades to reduce it from hitting the Intercooler piping over the radiator ? Thanks
