Hey guys,
Just thought id write word of two about my new little toy, after selling my r33 this is the only car i actually liked - nothing made me smile more. The beauty of RS Clio.
Done couple of little mods to the car just to differ from the rest :P
So far the list is;
Braided brake lines
Ferodo DS2500 pads
Camber pins, -1.7 Left, -1.4 Right - Toe 0.5mm out Left, 0.5mm out Right (1.0mm total) so much more grip and sharper turn in!
Remus exhaust
Eibach springs
My all time favorite, Mille Miglia HT3 wheels with michellin pp2 rubber!
Samco sport air pipe
BMC CDA Carbon intake - sounds like a wounded animal hehe :(
Various sound system upgrades and very dark tint...
odyssey pc680 battery
Almost forgot, home made front splitter :)
And of course 30hp TOY number plate!
Im sure i missed the little things out but thats how far i got it for now, not finished yet!
It loves to be trashed, and toyed with!
Love it or hate it :)
cheers
vlad
Edited by dovla
https://www.sau.com.au/forums/topic/243668-i-present-you-my-shopping-trolley/
  • Replies 44
its uh... cute...
haha, looks pretty decent dude, handle well does it?
Straight line speed is not this cars strong point, but to be honest it does keep up with most of the cars.
Handling wise, i already gave grief to couple of subby boys in the hills :P
Edited by dovla
errr shouldn't you be posting this on a Renault site? :(
Sorry, hate it. Unless you have a vag. But even my wife wouldn't drive a frog car (yes, I know they now own Nissan, but that's not an issue) :P
Why not post it here, im sure many members here dont have a skyline.. at least i had one :)
no offense meant mate .... was just pointing out that surely members of a frog-loving community would have much respect for such a car .... however opinion here may differ. Imagine the response one would get on for posting up about a new Skyline acquisition on a Renault club site - a fair lynching, I would imagine :P
Non taken! Believe it or not, were revving about new GT-R on our forums. Great car doesn't need a specific community to be appreciated thats my point, not talking about my car.
Oh crap, work in few hours!
I quite like it. Friend of a friend has a Clio (sporty one, whatever the model) and he raved about it, as did my friend who drove it. FWD still sucks ass for REALLY spirited driving (I know I own an SP23) but overall looks like a fun package.
Love it - and remember that Renault is owned by Nissan these days, or is it the other way around??
Anyway, if dovla can drive, this froggy girl's car would hand your arse to most Skyline drivers on here through Chain of Ponds :)
Anyway, if dovla can drive, this froggy girl's car would hand your arse to most Skyline drivers on here through Chain of Ponds :P
Confucius say, "it not how fast yoo go up mountain, but how good you rook getting there"
some little buzz boxes like ur clio can be HEAPS of fun... my bro in law had (till recently) a worked pug 205, i have never been in a car that u can throw at a corner as hard as that. awesome for motorkhana and hills driving.
however oversteer > understeer when u step on the loud pedal
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
