Well stop by the shops today only to come out to see a big smash in the back of my silver R33, almost broke down in tears, doesn't looks look like there is any structural damage but the rear bar & rear driver's side tail light has been seriously damaged, Looks like i was hit by a 4x4 bull bar, just wanted your guys opinion on Oakleigh Mechanical Repairs I was about to go see their parts until I read some threads talking them down a little, they quoted me $150 for a complete rear bar of the same color although I'm not sure if it's Type M so i'm going to have to go check. Been searching through the wrecking threads everything looks outdated or sold so if anyone has a spare silver 1.5 R33 GTS-T rear bar or driver's side tail light give me a shout, oh and I checked the local wreckers and workshop thread, looks outdated (numbers are dead and websites don't work for some wreckers) wondering if we could make a more updated list?...just an idea
https://www.sau.com.au/forums/topic/243807-just-been-hit/
  • Replies 42
That blows. I cannot stand dishonest people. Hope it gets fixed soon.
I know the feeling, its happened to my Bluebird ages ago - swipped the wheel arch (end of the day is doesn't matter the car) - but the thought of someone coming smashing up your ride and not claiming responsibility just s*its me.
https://www.sau.com.au/forums/topic/243807-just-been-hit/#findComment-4248414
Sorry to hear mate... I know how you feel... I had my window randomly smashed a few months ago - felt like killing someone... but hey, it's not that bad... it's time-consuming at most... first of all, look for a spare backbar, then a find a second hand set of rear lights... then get it fixed... I suggest you go to DT Panels in Springvale since you're in that area - they do a good job but a bit expensive, see how you go.
Good luck.
https://www.sau.com.au/forums/topic/243807-just-been-hit/#findComment-4248505
Thanks for all the support guys RBPOWA just gave me a hook up and he's sourcing parts for me hopefully this isn't going to be to damaging to my wallet, really pissed though i did a small inspection and the paint is peeling off on the side panel bend (next to the rear light) I'm scared there is small damage to the side panel hopefully it wont be too bad cause that would be a bitch to replace
https://www.sau.com.au/forums/topic/243807-just-been-hit/#findComment-4248667
horrible to hear mate, hope they get what they deserve and your car gets fixed properly.
if you need to go to oakleigh smash repairs they arent bad, paul is ok. they did my 5 stud and turbo brake conversion quite cheaply and well...
but i stopped using them for mechanical stuff after they sold me an old generation hypergear turbo with a chipped fin for the same price as a new one, which I showed Tao, the owner of hypergear and he told me he sold them that turbo ages ago for demo purposes only.
they were ok about it though, took it off for me for free and gave me my money back, just wish they didnt lie to me.
so just make sure you know everything about the part you get before you go... just to make sure..
part wise though they are fantastic, always have eveything I need.
Also, because you are in the area, near me, mckinnon smash repairs on north rd oposite dunkin mckinnon oval are apparently one of the best car repairers in melb, done great job on my car, twice.
may I ask where it happend? might be where I am thinking of...
best of luck with it.
Adam
https://www.sau.com.au/forums/topic/243807-just-been-hit/#findComment-4248824
Thanks a lot TJ, you've been a great help, I'm hoping to get the car fixed next week....Looks like it's going to be a lot of man hours but I got this car for the experience too so this will be good for me in the long run...just not for my wallet haha
https://www.sau.com.au/forums/topic/243807-just-been-hit/#findComment-4248933
It'll buff right out... :P
HAHAHA thanks htial, I needed that, yea I'm sure it will buff right out....when I replace em, I was meaning to respray the bottom of the bar anyway guess this saves me that job lol. Thinking of removing the lights and bar today just to see if there is any damage to the underside
https://www.sau.com.au/forums/topic/243807-just-been-hit/#findComment-4249499
UPDATE: Just went to paulies, gave me a good price in the things I needed but the color is wrong, did have a rear bar in silver but it was an aftermarket part so it didn't fit now I have the parts in white so going to take them to a beater to get them resprayed, also there is structural damage unfortunately if you notice the trunk sticks out like a sore thumb it's not because the light is smashed but because the whole frame was bent in I'm hoping the beater can fix it, will post pictures soon
https://www.sau.com.au/forums/topic/243807-just-been-hit/#findComment-4251799
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
