  • Replies 50
Lol, what's the different between that and cwest one? it looks similar, I think I should look at the real one,
anyone in Perth got white full bomex kit r34? Saw the guy around winthrop or murdoch or myaree :D
Ok you guys hate cwest kit :D I just got my r34 back from panel beater with full cwest kit
Originally posted by Mordy
has anyone got any pics of r34 bodykits? l have only seen a few nismo ones, are there anymore out there?
Cheers
dude I finally found the link I was thinking of, try here and select the diffferent manufacturers down the left side - some have 34 kits and some dont!
http://www.skylinesdownunder.co.nz/tech/bo...t/bodykits.html
hope its not too late :P
you would need to either cut the nose off or replace the GTT bonnet to make a BNR34 front bar and grille fit - but do-able.
i was speaking to a bodykit manufacturer/supplier (i prefer to think of them as copiers) and they said they were replicating a BNR34 front bar to fit an ER34. i dont know where it's at the moment though.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
