  • Replies 77
Hi all,
Got a s1 r33 gts-t not long ago and am thinking about getting it serviced by a workshop instead of doing it myself like usual as I've gotten incredibly lazy.
I'm looking at getting a complete service done so just trying to figure out how much I'm about to throw out of my wallet.
Things i want to do:
all fluids
all belts
all filters
spark plugs
tune up
What do you guys reckon?
Who is the best to do this work but doesn't charge an arm n a leg?
you want the uleh tune cost lost mahet << the h is silent :D
100,000K service from boost works cost me $600ish so add a little more for extra belts which you prolly dont need and sparkies would set you back about $25 for coppers standard ecu doesn't go out of tune so that's really a buzz word
oil change is from memory $150 @ boostworx
Its done 104,000
well, more like "104,000" if you know what i mean... im guessing its in its mid to high 100's like most of em.
hence why id replace most of the stuff.
btw, the car has a flat spot at 5,000rpm on full power, not always there but sometimes it doesn't wanna go over without a fight. ideas?
im thinking spark plugs might be the (or part of) reason why.
sparkies usually give a popping type boost cut feel i would say not going over 5,000rpm could be dry solder on the AFM
i reckon i did my 100,000km @ 143,000 because i bought the car @ 123,000 and assumed it may have been done
also if you've boosted the car above factory it could be R&R stopping the car making peak performance so things don't go bang just nissans way of user protection
that's pretty much what it feels like, sort of misfiring but not so harsh.
the car is running stock boost.
where did you get your 100,000k service from? boostworx? what was done?
if u want a oil change, gear box and diff oil change i can do it for you. Brothers got a hoist i can use.
oils arent really a problem for me, i just thought if I'm gonna do it right might as well get everything done at one place as changing belts etc.. aren't something im confident in doing.
ill ring around a few places tomorrow but will let you know. :D
Edited by tx3_90
Its fuel cut. Try getting a stronger fuel pump or if that doesnt work fuel cut defencer (use only if the ecu is cutting you off not fuel pump itself). Its nothing to do with sparkies.
Edited by Rocky88
Ryan for a private service/tune, or Boostwerks for a shop service/tune
($450 ~ $650 for 1st and 2nd option is the going rate)
best if you buy the parts yourself, ie 5L premium 10/40w oil, oil filter, fuel filter, coolant, power steer fluid, brake fluid, diff fluid (attessa as well for us 4wd'ers), bcpre6 .8mm copper sparkies,
grab a gates racing belt set for $300 (belt, tensioner, pulley, rings/seals)
oil and water pump for RB, around $450 there for new
might need the exhaust studs checked at same time.
probably advisable to check and replace gaskets, ie exhaust manifold, intake manifold, turbo gasket
but doing that adds up to a grand job.
although you then know she's good for a fair while longer now, probably for your ownership.
a safc and nismo adjustable fuel pressure regulator might be a bit of fun, to get around the 5000rpm spot, and gain some more power
but youd want a full exhaust system, good induction and intake, better fuel pump, and then the mods really start
so easy to fall under the spell LOL
:P
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
