hey guys and girls i am putting up my track car for sale/swap as i have now got a new job and will not be able to make it out to the track anymore.
specs:
R32 Gtst
S15 SR20DET conversion (completed in japan)
S14 5 speed
211rwkw on 1.2 bar
Power FC and hand controller
OS geiken twin plate clutch ( recently rebuilt )
TOMEI 256 cams
550cc injectors
HKS GT SS turbo ( less than 1000ks done )
N/A SR20 throtlle body
Big internal fuel pump
xforce manifold
rb25 airflow meter
straight pipe
Big TRUST FMIC
GReddy triple core radiator
KAZZ 2 way diff
HKS coil overs
camber adjustable
Brand new Whiteline Adjustable 24mm sway bars front and rear
Brand new Kazama Adjustable Castor rods
hicas lock bar
drift pineapples
SPARCO driver's seat
GTR interior
shift knob
turbo timer
sparco steering wheel
boost gauge
Racing pedals
Strut tower brace
Drift style handbrake
body kit is genuine BN Sport kit
evc 4 set to 1.2 bar
WORK miester 3 peice rims.. fronts 18'' by 10'' and rear 18'' by 11'' new tyres on the rims.. front 255/40 rear 275/40
Full wide kit 30mm rear and 25mm front.
Car is not complied but can be.
looking for around $13,500o.n.o but may swap with cash adjustment either way
https://www.sau.com.au/forums/topic/244271-sr-r32/
so by removing the engine and replacing it with a standard rb20? hence removing all the engine mods.
bit misleading to say it can be complied, and not state you would probably have to spend a few thousand to do so.
don't take me wrong, the car is excellent value for the work done and the money it would take to get a r32 to this state. the mod list is impressive to say the least, but wouldn't exactly say it is compliable.
https://www.sau.com.au/forums/topic/244271-sr-r32/#findComment-4254895
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
