Yea but im sure that rb30 was build to handle 30+Psi lol
Can front wheels and covers be swapped over like rear ones?
Yes they can but you will find it is a very expensive exercise! Rear housing from Garret from memory was $600+
And yes +1 to a .63 housing being way to small on a 3L it will choke up for sure IMHO it is a bit of a misfit size in the Garrett range...
The .82 is not too bad on a stock RB25 more suited to a built motor but it will be a good balance between not having to buy a new turbo when you get the 3L cause a .82 on a 3L is a response monstor :domokun: I personally have a 1.06 rear on my 3L and wouldnt have it any other way as it feds on the power so nicely. Also I might add mine is internal gate and am having no problems with boost control 7psi actuator and a Turbosmart T and holds dead on 15psi.
And is it definately internal gate?
hahaha
Thanks for the info guys, For now i think im going to wire the Internal Gate shut, Mod my manifold to house an external gate and still use the .63 rear. I like it at the moment how i can cruise around at the moment like everything is normal but flat foot it off the line in first and it doesn't break traction. If the .63 generates too much heat ill put an external gate rear .82 housing on the turbo and keep it that was until i wack it on a 3L.
Thanks for the Info.
Hey guy,
I think 'the mafia" did a gt30 with a .63 rear end. Search for his threads. I dunno if you're already onto it, but it makes for a good read.
Also, just something I would consider if I was in your shoes... Why don't you use the GT35 with a ext gate setup until you get your 3.0l
from what everyone on hear says, the ext gate spools the turbo quicker, and then you have an upgrade path. You may or may not want a .82 rear house when you 3.0l, but that's then, not now.
The .82 is not too bad on a stock RB25 more suited to a built motor but it will be a good balance between not having to buy a new turbo when you get the 3L cause a .82 on a 3L is a response monstor :( I personally have a 1.06 rear on my 3L and wouldnt have it any other way as it feds on the power so nicely. Also I might add mine is internal gate and am having no problems with boost control 7psi actuator and a Turbosmart T and holds dead on 15psi.
hahaha
You have the XR6T version yeah? with the 0.50 front cover?
How does that affect compressor flow?
I do but also have a .7 cover
There is no noticeable difference between the .5 and .7 without changing the tune, might get some gains when it gets retuned though...
I have found that bigger turbo's with low boost make heaps of wastegate air. So if the gate is too small, and or the waste gate dump is to small, the issue comes where the gate cannot dump enough gas to stop the turbo from spooling up.
yea we figured that one out, going external gate so will resolve that...I was talking more of whether the .63 rear can flow enough through it to cope with the gt35 front cover and the volume of air its producing to not create too much heat.
If i were in your predicament, i would seriously consider selling it and buying a proper matched turbo. As you seem aware, a 3082 is behind the 8 ball, as teh ex wheel is too small to generate enough torque to accelerate the rotating mass quickly. And by using a .63 exhaust, it is partially alliviating that, but adding high backpressure to the equation. I would be fitting a .82 3076, as IMO it is the ideal turbo for an rb25 after 280-300rwkw. Even if you fit the rb30 (which i dont think you will need to)the same turbo can be used, and fry the tyres up to the legal speed limit with more response than you can poke a stick at. If you feel you must have more than 300rwkw, then bite the bullet and get a real gt35r, with a .82internal or you can get away with an external gate .63, but i believe on pump fuel the exhaust backpressure will limit the power to far less than the comp wheel is capable of making. We need something between a gt30 and gt35!
i find this topic interesting....
Just incase anyone cares...
my gt35 with .63 rear isn't as laggy as you'd originally expect.
3000rpm = 0.56bar 8psi
3500rpm = 0.82bar 12psi
4000rpm = 1.04bar 15psi
Once external gate is fitted should be fairly good.
Just hoping the .63 rear doesn't choke up the gt35 housing too much in the top end. For the conservative boost ill be using it shouldn't.
^^ thats fairly laggy IMO.
I had my GT30 .82 on by 4200rpm and was over 15psi and make more power than you will be able too :yucky:
500rpm to get that last 3psi once spooling is indicative of the large compressor side
after 4k the boost sky rockets but thats when i back off, yet to see what it does after that.
yea but at the end of the day, It's all about experimenting....gimme a break...i just spend 2k on this turbo, gotta stay positive hehe.
I'm not doin it to beat anyone else...doin if for my own thrills.
It's fairly laggy i know but off boost it drives great and doesn't break traction which is what i was after.
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
