Lines In Cairns
heh
i grew up in cairns and my grandparents live on teh tablelands
(mareeba and malanda and formerly tolga, just outside of atherton)
ive seen a few soarers (but no skylines) while ive been up there;
https://www.sau.com.au/forums/topic/24449-lines-in-cairns/#findComment-522834
Originally posted by Spooks_Skyline
heh
I am staying in atherton and working down at the tinaroo dam, we are building a mini hydro electric powerstation at the base of the dam.
Lots of old people around here and lots of old 4wd's around.
https://www.sau.com.au/forums/topic/24449-lines-in-cairns/#findComment-522978
I spose a Skyline doesn't make much sense up in the tropics. Its to hot and the roads can't be that great. Although the roads in Townie were OK. They had great wide corners without much traffic and with nice smooth long straights. Leewah was there aboout 2 weeks before I went up and thought that out near the airport in Townie there are some wicked long stretches where his monster could have had a crack at the big three zero zero.
Both Leewah and I agreed that our Lines should go with us next time.
https://www.sau.com.au/forums/topic/24449-lines-in-cairns/#findComment-524494
Around where i am the roads are really nice and smooth, but they are very narrow so if a truck is coming the other way u have to put 2 wheels on the dirt to avoid a head on.
I got the shitty BA falcon upto 210 easily, leewah could wind out 300 around where i am easily!!
https://www.sau.com.au/forums/topic/24449-lines-in-cairns/#findComment-524496
Hi fellas,
I'm a Cairns resident and will be back in town on Thursday with my latest acquisition. Metallic black R34 GTT (plated 34-GTT). It has some mods but nothing too over the top. I think I'm going to have to do the Rex Range Rd up through Julatten and Mount Molloy as soon as I can.
There are a few Skylines around. The boys at Autobarn in Cairns tell me that there is an R34 GTR in town as well but the guy only wheels it out on weekends.
Cheers
https://www.sau.com.au/forums/topic/24449-lines-in-cairns/#findComment-528766
I'm up around The Port and Cairns for my honeymoon in mid-late october this year. Hope to see a few 'lines to remind me of mine at home in bed (and to piss of the wife when i start waving frantically and yelling, "Skyline SKYLINE LOOK !!!! AAAHHH!!!"
umm.... ;)
does anyone else do that?!?! thought so :D
Adrian
https://www.sau.com.au/forums/topic/24449-lines-in-cairns/#findComment-529035
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
