i just changed my r33 airbag wheel to a sports wheel. the wiring i have from the bosskit only has one bit that goes to the horn button and another bit hanging off it that looks to be a fuse but i cant see anywhere to earth the other bit of the horn to. would the fuse bit be the earth now or what? i didnt get another bit of wire to put on the other horn terminal on the horn pad like i thought you usually use to earth like commodores and stuff. any info on this mates?
also i needed to remove the fuse from the fuse box from the horn coz my old horn was sticking on and i dont have a fuse box cover so i dont know where to put a horn fuse and what voltage it is. can someone scan up there fuse box lid or tell me what one to put in and which slot to put it in please
https://www.sau.com.au/forums/topic/244718-just-changed-r33-steering-wheel/
LOL :yucky:
mate... alot of electrical items need earthing.. houses for example.. it's not just commodores.. now i'm not sure if it's the same sorta kit (ours was hooked up to a hilux).. but i think the boss kits have their own ground on it.. so that extra wire can just be tucked away down the middle of the boss kit..
i was using the commodore as an example not implying it was the only car thet needs to be grounded.
there is no spare wire to leave hanging. there is one plug from the car which plugs into the wiring for the bosskit that goes to one spade bit on the horn button. there is another wire handing off the side of the new plug which goes to the horn button. would that be the ground now and i just leave the other spade bit on the horn button with nothing connected?
id test it but i dont have a fuse connected to the horn in the fuse box so i dunno if its right
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
