I wont be able to get any decent pics of them until later on in the week. But im sure if you come and look at them Steven you will snap them up.
post-32255-1228108645_thumb.jpg This is a scratch on the underside of one of them. Cant see it once fitted to the car though.
Other than that they are in good condition.
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
