Victorian P Plate Rules
@Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
You are selling this? I have never bought something from marketplace...i dont know if i trust that enough. And the price is little bit "too" good...
By Watermouse · Posted
https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr -
