Benji's S13.5 Thats Really Wants To Be A R32 =d
well I thought its about time I post up on my just finished s13.5
ive been building it up for the past 20months+ and starting off with less than a rolling shell n yeh went from there...
and as everyone could say this.....but I SWEAR! it wasn't meant to turn out this crazy it was only meant to be drift teks, vg30, fmic, xhaust, welded diff, and get the boys round with a few cubes of bundy and matte black spray can paint job =D
but one thing lead to another and ended up like this...
here is the specs:
Engine Bay Specs;
RB20DET Conversion
Custom High Mount Manifold
Custom ASE Intercooler Piping
Custom ASE Screamer Pipe
ASE Dump Pipe
ASE Front Pipe
ASE Custom Made Overflow Bottle
ASE Custom Made Catch Can
ASE Z32 AFM adaptor
Hypergear TR43 440hp
38mm KKR ext wastegate
GKTECH R32 FMIC Core
Cooling Pro 40mm Triple Core Radiator
12' Davies Craig Electric Thermo Fan
Buddy Club 3" Straight Thru Cat Back Exhaust
R33 Power Steering Pump with custom lines
Tomei adjustable cam gears
TRUST Oil Filter Relocator Kit with Braided Lines & Earls Fittings
Sonic Turbo Blanket
Z32 AFM
GTR R32 Coil Packs
GATES timing belt
K&N Pod Filter
TRUST Radiator Breather Tank
TRUST Oil Cap
TRUST Radiator Cap
Fuel System;
Walbro In-Tank pump
Bosch 044 ext pump with BTR ext fuel pump bracket
SARD 800cc Injectors
BTR Surge Tank
Turbosmart Fuel Pressure Regulator
Drivetrain Specs;
RB20DET Gearbox
R32 GTST Rear Cradle Swap
R32 Cross Member
R32 LSD Shimmed Diff
Reverse Mount Front Sway Bar
WheelWorx Spacers For Rear
Turbo Tune Custom RB20DET Engine Mounts
Turbo Tune Custom RB20DET Gearbox Mounts
S14 Front Hubs & Stub Axels
S14 Brake Master Cyl.
DBA XS 4000 Series Cross Drilled & Slotted Rotors up Front
R32 GTST Type M Cailpers at front with Hawk Pads
Xtreme Drift Clutch
Xtreme Billet Flywheel
D2 Hydraulic Handbrake with custom lines
Full Welded In Roll Cage
Interior;
Full Stripped inside
Custom Rear Fire-wall Plate
Complete stripped of Sound Deadener
Sparco Sprint V bucket Seat
Sparco 4 point 3" harness with rotary button release
TRUST gear Knob
OMP Style Steering Wheel
Fire Extinguisher Kit
Re-Located Battery To Behind Passenger Seat Position
Suspension;
HSD HR Coilovers
HICAS Lock Bar
TGP Drift Pineapples
Project D Adjustable Rear Camber Arms
Project D Front Castor Arms
Whiteline strut braces front and rear
Wheels;
Work Emotions XT7's in 18x9.5 +12 all round with Bridgestone stretched 235/45R18s with Blue Rays Wheel Nuts
Electronics;
HKS EVC 6 Electronic Boost Controller
Remapped ECU by Turbotune
Defi Style Gauges (Boost, Oil Press, Water Temp)
Custom Control Switch Panel & Kill Switch
Aftermarket Alarm + Central Locking
Aesthetics;
Sprayed in Bayside Blue with Azureus Blue Pearl and Black roof
Strawberry Face Conversion
S13.5 30mm Wide body Conversion Front Guards
S13 50mm Wide body Over Fenders
Full Vertex Kit (s15 front bar, s13 sides and s13 rear)
Custom "Air Dam" for vertex front bar
Vented S15 Hood
Origin GT1 Side Mirrors
Origin Smoked s13 Rear Lights
Origin Carbon Fibre Rear boot lip
Origin Front Bar Carbon Fibre Canards
Origin Side Skirt Carbon Fibre Canards
Origin Carbon Fibre Rear Window Spoiler/Lip
CA18DET Boot Lock Badge
Sparco Hood Pins
D1 Spec LED Strobing Parkers & Reverse Lights
16000k HIDs for Low Beams
Future Mods that will be done by February:
- GTR Box Conversion
- Custom Instrument Cluster (APEXI RSM, Autometer Colbat Fuel Level and Air/Fuel Ratio)
- Custom Made HyperGear 50mm External Gate with Screamer Pipe...
and that will be it for now... to complete the package
atm is making 210rwkw on 14psi as the 38mm wastegate too small and wont hold much more boost... have made 230rwkw on 17psi before but wastegate couldnt hold it..
and have got trouble with hks ebc atm so when that's worked out will be all good.. but its super responsive atm.. and the power its making is a safe as tune...so plently more left in it..
but atm still bakes 2nd and 3rd so yeh ill get used to it and then turn it up a notch I reckon =D
here is some pics now you've read all the specs =D
enjoy....=D
and now for the best pic of them all hahah =D...me taking the piss out of a serious situation.... =D
Cheers,
Benji
Edited by Benji
saw you driving on south rd a few weeks back, certainly a hot car, kudos to you :(
cheers bud... yeh man been waiting for someone to say they spotted me haha!! kinda doesn't blend into tha crowd so yeh!! chuck us a wave next tym...!!
Awesome car mate, you must be very proud. there's only one thing i dont like and thats the fuel cap sitting in its original spot, apart from that it gets the :(
thanks man....much appreciated, and yeh never thought it was going to turn out as well as it has, im effn stoked to say the least!! :)
have looked over your car quite a few times and love it to bits!! :banana:
but there is a reason why I have done that bud, and that's so people appreciate the actual width of the rear fenders, cause with the widebody fuel cap it nearly looks like a std guard to a extent if you get where Im trying to come from..
and hadn't seen many done when I had it painted like that... so when you see the fuel cap sunken in like that you get the idea, then you actually see my sil has massive hips =D!!!!
Edited by Benji
geez what a list!
thats a pretty cool ride you got there mate, great job
thanks man
yeh the list I didnt expect to be that long until i had to sit down one night and right it all out and yeh started to remember shit I forgotten I had done haha!!
and the list still getting bigger haha!!
:ph34r:
nice, that cars had a massive sex change operation haha......like 3 in 1
ahahahahahahahahahahah!!!! yeh I guess you could put it like that...
or the surgeon got bored of just doing the normal sex change and decided to add a few things and get creative haha while they were out cold!! :ph34r:
So when do we get to see this car in the flesh???
mmm maybe next sau cruise/dyno day depends if i get my box done in time, n my dash done.....
Seen your car driving around a fair bit mate. Saw u saturday drive past my work on morringe ave. love it.
btw how much did btr charge you for your surge tank?
yeh seen your 4dr around as well luke man n f**k its tuff as man!!
arrrr k i hope I was behaving myself then LOL
mm i got it off a gd mate, who own it as a prize, but round the 100-150 mark I believe... ring Leroy n he will more than be willing to help ya out buddy...
Edited by whatsisname
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
