Originally posted by Ronin 09
Anyone had one fitted? What gains have you found? and how much would you expect it to cost?
cheers
I got a hks exhaust cam gear put on recently but with a whole bunch of other stuff so i couldnt tell u exactly how much ice charged me for it. Change your timing belt when u get it installed 2, if u already havent done so. We havent really played around with mine as yet because we are waiting for the new turb to go on. At the moment its set to -3 degrees i think.
(quick thread highjack)
SydneyKid - in your opinoin, is it worth while installing an adjustable exhaust cam gear when your still using the stock R33 GTS-t ECU ?
I think around -3 degrees is around the normal for the typical mods (boost/exhaust/FMIC). Does that sound right?
(/highjack off)
Hi Guys, for RB20 & RB26 we do both, commonly 1 degree advanced on the inlet and 4 degrees retarded on the exhaust. On RB25's with VVT, we only do exhaust with around 4 degrees retarded timing. We use Jun pulleys.
We have been finding lately that the good aftermarket camshafts actually don't benefit much from adjusting the camshaft timing. They are pretty much perfect with their "standard" timing. So if you are looking at doing camshafts (highly recommended on RB25's) don't bother doing pulleys.
I always recommend changing the ECU very early in the modification trail. Normally..........
1. turbo back exhaust
2. Upgrade fuel pump (on GTST's but not GTR's)
3. Boost up
4. Pod filter, heat shield & CAI
5. ECU
6. FMIC (on GTST's but not GTR's)
6. Turbo upgrade
7. Pulleys or camshafts (on GTST's, both on GTR's)
As you can see, pulleys are a fair way down the list.
Hope that makes sense
Sydneykid,
Should i spend $400 on the two pulleys? how much would appropriate cams on an rb20det with my setup cost? is it worth it?
Setup will include
RB20DET
Turbo Back Exaust
Custom plenum
PWR cooler
GTR injectors
Wolf 3d v4
Garrett GT28
Evan
Hi rb20-calais, used HKS 264's go for around $700, they work a treat in RB20's. As to whether they are worth it, well that really depends on your target power and what you are going to use the car for.
What I always suggest is to pick a power target and then match the components to that target. It is no good having a 220 rwkw turbo with a 330 rwkw intercooler, with 250 rwkw camshafts, with 200 rwkw injectors and a 290 rwkw fuel pump being stangled by a 170 rwkw exhaust.
Hope that helps lead to a conclusion
The problem I have had when modifying my car has been "at what point am I satisfied with the power". Its hard to know at what point, or hp, you will be satisfied with it as in the end you'll want more. And because you thought you'd be satisfied with the 320hp turbo, you'll find you will now have to sell it to buy the 450hp turbo, or the 550hp turbo and so it goes on. I'm not disagreeing with sydneykid, as I also believe you need to match as many parts to each other to get an overall excellent package, its just hard to know how much you want. I've got a turbo that will support 450-500hp, an intercooler that will support 500hp flow, but I find the turbo a little laggy and slow. I'm hoping with the new ecu and a HKS cam gear that will help the response. I may also look into the lightweight flywheel, lightweight pulleys (if anyone makes them) for better engine response and maybe some cams.
Also given time you get used to the power and generally want more :) I think that the best policy should be buy products with enough headroom should you want to upgrade to more power. ie: if I want more power now I just run more boost :) but I have to put other supports in place for that; ie pistons, bigger injectors. etc
Hi rob77, my answer was for an RB20DET in a Commondoor. An RB25DET in an R33 GTST is a totally different question.
Do you want to leave the internals of the engine standard or not!
If you do then answers are then very easy, everything needs to be set up for 450 bhp. Because that's the most you are going to reliably get out of an RB25DET with standard internals. So you use everything for that maximum, as you said if you don't want that much then turn the boost down. Simple.
If you want more than 450 bhp, then the question is again simple, how much money do you want to spend?
That's why RB engines are so great, there is enough information around to do whatever you want. You just have to ask the right questions.
Hope that clarifies
So back to the original question...
How much would it cost to have just the ex cam gear fitted and then set to -3 or -4 or whatever it is? (ie no dyno or ecu tuning).
No point getting an ex cam gear -yet- if its going to cost as much to get fitted as it will to buy it.
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
    • Decided for the first time ever I would tow my car TO the track day on the same working theory as bringing tools and spares "if I have it I wont need it, but if I leave it behind i will 100% need it" all setup and ready to go out and try these A050 for the first time First session showed I needed to stiffen up the dampers a touch but still managed a few 1:21's without much effort. things were looking good. Came in a dropped the tyres down  to 26/28 as they had gotten to 35/33C from 22C cold The first lap of session two I managed to drop into 1:20's. Then in the second lap into the second session. Coming into T3 and I suddenly lost brake pedal followed by some huge rear end vibrations and scraping sounds. Got it back into the pits after session ended and found this. in the attached video, all of the wobble is in the hub its self, wheel is mint, and bearing feels tight. lKXLqpd - Imgur.mp4   Deciding it was a bent spindle I tried to find bearing/hub assembly locally but was unsuccessful so it was loaded back onto the trailer i luckily brought it on to drag it back home
    • 1.05 you’ve gotta let it breath
    • You have to continuously fill it to avoid dry running. Personally the transmissions I've serviced have never been bad enough to justify doing this because it is definitely a pretty complicated and somewhat risky procedure compared to simply draining the pan, measuring what came out, then refilling with the exact same amount.
