i beleive that the federal police have some kind of control over airport property. back in the day when the airport was the 'place to be' we had run ins with them.
trust me, the 'feds' are not to be messed with. think of someone having 2 times as much power as a regular cop but without the smug, i'm better than you attitude.
I work out at the airport and regularly see the police on Airport Drive. They've been booking quite a few people lately in the 60 zone where they are doing roadworks. Also I've seen them in between the International and Domestic Terminal roundabouts catching people as they approach the Control Tower complex where the speed limit goes from 60k down to 80k.
Originally posted by slip
nvs, you must bring your GTS2 out on a cruise, us 31 guys will love it.
Yeah I would love to go cruising with the R31 guys. I've been keeping an eye out on R31SkylineClub.com, but nearly every time theres been something on in Brissy I've been working or organised something else. Would like to check out the next track day at willowbank.
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
