Gt35r Vs Garrett T04z - Discussion (just Post In This Thread To Create A Database)
Good job, I guessed your weight at 2800lb?s and put your run in the Power calculator and it came up at 560hp so the numbers sound right.
http://www.turbofast.com.au/Drag.html
Reasonable guide but remember its engine power. Im surprised just how close this has been.
unless he's using carbons bits, his wet weight (with fuel and driver) is more likely to be around 3100lbs..... (just over 1400kg's.)
EDIT: is this in a skyline ?? just read his sig mentioning an s13 in which case ignore the above :>
hey guys how you all doin.
i was hoping for some advice since most of the power experts seem to gather in this thread.
just made 320kw @ 20psi on my rb26/30 but thats all it will make.
the heads completely stock apart from having some minor porting and polishing. gt35r, .82 rear, 6boost manifold, standard gtr plenum. some ppl have suggested valve float and to get new springs. i was just wondering if anyone had any other ideas before i take the plunge on the springs.
theres so many gt35r .82 users smashing 400kw on a rb30.....and i cant sleep at night knowing im not apart of that club lol
any thoughts much appreciated.
::edit::
after skipping though the thread a few more times i came across some stupid, premature and quite naive comments i made.
i dont think you realise what you are sayiung.
im telling you he did not make 400kw on a .8 gt35r
i guess i was just taking my poor build out on others and im sorry. i just hope those of you will forgive me and show me on the right path.
Thanks guys
Edited by Jap_Muscle
We told you months ago about the valve springs probably being the issue - still not tested i take it?
hey ash,
no unfortunately i havnt. i just managed to save up 3k for a Nismo Super Coppermix clutch....and just put that into the car.
i just wanted to gauge any other thoughts on what the issue may be.
ive done a bit of reading on valve float and from what i understand its when the springs are not in contact with the cams or something right? if im running standard cams should this still be a problem? i thought this was only a issue when the cams are upgrading to bigger ones with bigger lifts?
getting a bit off track i know....but if anyone could entertain me just this once id really appreciate it.
how does one tell if his build is indeed suffering from this? is there something he can hear/see or read from dyno graphs? have any of you rb30 gt35r uses upgraded your springs?
lastly, should I be getting springs to match the standard cams or should I get a set of 265cams with matching springs ?
Maybe someone get shed some light on my current set-up and the issues I am having...
Im running a built RB30 bottom end with standard 25 vct head. The old set-up was running a GT3082r (0.82r) with 6 boost and supporting mods and made 280rwkw @ 17psi. This is through a built 5speed auto, fully manualised with 4500rpm stall.
I then changed to a GT35R with the same mods. On 11psi, the car made 246rwkw @ 7100rpm. We then upped the boost to 18psi, however the car only went 260rwkw and stopped making power after 6000rpm (sharply).
Any ideas what this could be? A few people have mentioned valve float but I also dont know how to verify this.
After the 18 pages or so i think its about time i needed to chime in on this thread,
i'm up in the air when it comes to turbo selection for my Built stock capacity Rb26, since i've not seen the motor yet i'd say i've had a fair bit of porting/head work done since i put in 270 cams and 11.2 lift..
now i am really up in the air on which turbo to choose. since i want some silly power but would like something responsive too. i guess this gtr's rev range is going to be alot higher up now with the cams. so anything under 3.54k isnt going to concern me. My old N1 high flows came on hard at 3 and pulled till 9 i may go back to them if i dont get the right single.
Gt35 seems right... but i wouldnt mind a bit more top end and they dont seem to go over well over 25psi according to a few here?
waiting on the results from the 3788r
and the 4088r might be right.. but could be a bit too doey down low and not even crack positive boost untill 5k
perhaps a different companys turbo should be on the cards? i've not even thought about the garrett to4z or hks equivalent but should i think about it?
And then on top of it all what rear housing? i'm guessing a .99 or 1.0 or something dew to my head flowing alot more. will be running split pulse too..?
every other aspect of the car should be up to the task, box, diff, fuel system, brakes, suspension.. but maybe not the driver haha.
If I were going for a fast RB26 powered car and a GT35R wasn't going to cut it, I'd be running a .95a/r twin scroll GT4088R for sure. I'm hoping to catch up with a mate of mine this weekend who is running the same cams as you and a 1.06a/r GT4094R (should be quite a bit laggier than a 4088R) on his stock displacement RB26 and go for a jaunt in that.
Its only running 13psi at this stage, but I should be able to get a good impression of spool etc.
Ah sweet, an update on that one in here would be greatly appreciated! my mate who works for a customs/exhaust shop keeps telling me to go bigger than the 35r and similar. i would love a 4088r however..
Cheers
Andrew
too much bigger than a 35R and on a standard capacity 26 the car will be no good for any circuit work as the power will be way too peaky leaving drag racing as about the only thing its suited for.
The Mines R34 GTR is one of the best "street"/track monsters ever and that uses GT2530s which are more comparable with a GT4088R than a GT3582R in spool, imho.
The 4088 is what 800hp?
2530's are around what, 320-350hp or there abouts? Not quite the same league...
How i cringe when the ole Mines comparo gets thrown around....
Mines is running what... different diff's, superlight driveshafts, and i think different gearbox gearing.
Its more about what is going on behind the motor than what is attached to the side of it.
270 11.2mm cams tho the rev/power range is going to be somewhat over 4-5k.. motor will rev to around 9500 or there abouts. big single might be the way to go i think.
exactly. i am running c/r gearbox also and cf prop shaft, might change diff's too but thats up in the air.. i think the big single is going to be good.
From what i can gather these cars run t88 34d's and are circuit cars. and looks fun
a bit of playing around it looks like
This is a few quick laps from him
GT4088R is suited for 400-700hp, GT2530s are as you say 320-350hp x 2 = 640-700hp. You reckon that it sounds far fetched that GT2530s would be more comparable to a 700hp turbo setup than a 600hp one?
And before you jump up and down about it, I've driven cars with GT3582Rs and GT2530s and if you had a roll on from "the basement" in 1st gear between a GT3582R .82a/r single entry (let alone a TS one) and a twin GT2530 GTR, I'd happily bet a hunger buster combo that the GT35R GTR would be gone before the GT2530 setup was wound up so long as all else were equal.
In regards to the "How i cringe when the ole Mines comparo gets thrown around....
Mines is running what... different diff's, superlight driveshafts, and i think different gearbox gearing. Its more about what is going on behind the motor than what is attached to the side of it."... well yeah, of course - that was the point I was making. Despite what a lot of people seem to think - the power level and how soon it comes on is not the final word on how the car is going to perform on the track.
An early spooling turbo would make life easier, but realistically if you are going for real fast times then the odds are you'd be looking at more revs, aggressive gearing and hearty power levels. A GT40 based turbo + big cams moves the rev range up, but the working area of the rev range would monster your typical GT-SS setup - just will also be harder on the attached bits, including driver.
Sorry I meant rated, hit Garrett up about the semantics as they are the ones who rated it to 400-700hp. GT4088Rs aren't as big and nasty as a lot of people seem to think... not that they aren't big and nasty, but ;)
Only 600hp in a .63 rear for the GT35 i thought.
Otherwise they are 700hp (.82) or 750 (1.06) IIRC.
Rear end does have a bit of a day in overall proceedings... damn turbos ;)
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
