Hi,
I bought these brand new Federal semi slicks last week and my intentions for the car have changed, so theyre up for sale. They are awesome tyres; they stick like sh1t to a blanket. My car is very powerful, and they handled it with ease. Very comfortable on the road with little road noise and no extra harshness.
The sizes are 235x45x17 and 255x40x17. The 235's are 595RS's with a UTQG of 180 and the 255's are 595RSR's with a UTQG of 140. The Federal rep said that this combination was perfect for street, track or motorkahna duties. For comparison, drag slicks usually have a tread wear rating of 60 to 80, and normal road tyres usually have a rating of around 240 to 300. I did a lot of research for these tyres, and for the price and all round performance (including wear resistance for street duties) these came up trumps compared to Toyo and Falken.
The fronts retail for $280 and the rears retail for $315, thats $1190 all up. Im asking $1000 for good as new tyres. They still have the little wobbly rubber things on them!
Contact me on 0414972596 for any queries.
Thanks,
Shaun.
Drag slicks don't usually have a treadwear rating on them at all.
OK, Thanks for that. I read it somewhere in the tyre section. I did, however, mean DOT approved drag tyres like the Micky Thompsons etc, but im no expert on those.
Its safe to say that these Federals are quite a bit more wear resistant than the DOT approved drag slicks. Thats the point i was trying to make.
Shaun.
They certainly are! These are bloody good tyres too.
FWIW, the DOT treadwear rating on Mickey Thompson ET Street Radials is...ready for this?
0
Zero
Zip
Nuthin'.
Hi,
Thanks,
Shaun.
What size rims are these on? Are you selling the rims as well?
Theyre on 17 inch rims, and no, theyre not for sale. Just the tyres.
Thanks Dave, ive still got your offer in mind. Ill give it a bit more time yet, as im in no massive hurry. If you met me half way, however, they could be yours today! :)
Shaun.
Edited by Shaun
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
