I just went to the movies down the road at that shopping centre
Saw KillBill, drove my car home wanting to kill everyone with a samurai sword.. which was a good thing .. kept my mind off how good my car was running and how fast i wanted to drive hehe
  • Replies 181
thks NismoGirl and Knore for recommendations on how to kill time there. guess i either drag my gf along or pop into the nearby cinema for a show then...
unless Gavin let me help him service my own car .... :bonk:
Nah, no ones allowed into the workshop unless they are escorting you to show you something wrong with your car. Which, come to think of it, I spend most of my time in the workshop than sitting down chatting to Amanda :|
One good thing about Gavin's and his mechanics is they like to show you things so you are aware of problems or what things do. When my car had the power problem, he showed me the consult machine to show me what was going on. I kinda understood it, but not really. I learn lots of things when I go down there :D
  • 1 month later...
Its going to be a good 350-400km round trip for me, mines up for a 100,000 service, however allot of the stuff is already done, like...
- Plat plugs
- Timing belt only
- Diff oil
- Trans oil
- Rad flush
- Brake fluid flush
- Fuel filter
- Engine oil & filter
I'll give them a call but can anyone give me a heads up on what else there is?
Do they do...
- Other belts?
- Injector clean?
- Compression test?
Ta for any info!
Only 1 more day till my car goes to gaven and gets a full service ,power fc, tuned on dyno and street and gets the AVC-R wired up and working :) cant wait to pick it up friday afternoon. i took the car to gaven 2 weeks ago just to get a check over as i just got it from japan etc. when i picked it up and asked him why arnt the turbos boosting till so late, his eyes opened up and he replyed with they are N1's your looking at 600hp+ after you buy a power fc and i tune it. LOL :) I CANT WAIT !!!!!
haha man thats crazy!!! Sounds like an awesome car. I was at Gavin's today im getting him to install my FMIC and tune my s-afc. He's heaps busy lately i have to wait 2 weeks as hes all booked out! I feel like such a tight ass when i go there because everyone else spends mega $$ on shit for their cars. He's still nice to me though even though he knows im poor :)
Dont feel like a tight arse. Every time that I go down there, I only get a service and I've been going there for nearly 2 years :rolleyes: I don't have the money at the moment to get anything done. Your lucky your getting a FMIC.
I don't know about you, but I'd rather spend less than spend more :) But that's just me!
Did he give you a price range as to what it costs to do the tuning and install of those two items?? How long does it take as well? A whole day?
Lucky man! I wish I had a pfc and an avcr :rolleyes:
nizmogirl, its about $750 to get it all done.
dyno run and all.
very cheap hay. it cost me over $1000 to get my VXSS V8 tuned with LS1edit on a dyno.
he said to drop of the car tomorrow (thursday morning) and it will take 2 days so im guessing friday arvo i can pik her up :rolleyes:
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
