hey all im in the middle of building a RB26 and am starting to strongly consider selling my 33 and purchasing an old nissan/datson.
was after some opinion of what to look into...
looking at a massive power to weight ratio.
i have thought of the obvious like 1600 and dato ute.. but is there any other wicked old skool cars out there???
and will it fit is prolly a good question..
i no some one has a 30det in a 240z
Dan
https://www.sau.com.au/forums/topic/246555-rb26det-into/
would love to put my 1000hp GTR engine into a Charger...C4 auto and massive rear slicks.
would run 8's at the strip.
Ive owned 6 Chargers in my younger days they are around 1100kg with the Hemi 6 in them...it would haul ass!!
https://www.sau.com.au/forums/topic/246555-rb26det-into/#findComment-4285731
Strawberry faced 180SX with an RB30 has always been a dream of mine
So have a 26 powered WB ute!
Strangly, I want to put a TT LS1 in a 33.
Would the engine fit into something crazy like a Navara or Hilux?
Gemini?
Van even?
I could on for days...
https://www.sau.com.au/forums/topic/246555-rb26det-into/#findComment-4286066
Gemini?
Van even?
lol @ gemini, when i had my lil gem i was considering a ca18 swap, rb26 would be bad idea haha power to weight plus youd have to cut into the fire wall etc etc.
buy my gf's FTO and put it in that! doo it. :blink:
https://www.sau.com.au/forums/topic/246555-rb26det-into/#findComment-4286674
old school volvo 240.
That well get some :blink:
Road or drag?
Road some light jap car of your choice
Drag any muscle car that takes your fancy, but you would have been better off with a gen3 v8. Lighter with possibly more potential
https://www.sau.com.au/forums/topic/246555-rb26det-into/#findComment-4286710
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
