  • Replies 78
Cars (Jap and big V8 muscle) ohh the sound..mmm
Music
Singing
THE RIVER!!! (tubes/kneeboard, harhn super dry, spa, boat)
Bodyboarding
Fishing
Good tattoos
Adventures with mates to old abandoned houses/buildings/graveyards
Holidays
My Car
Driving My Car
My Friends / Family
Friendly People
Pepperoni Pizza
My Strange Taste In Music
Cold drinks On A 30+ Degree Day
The Current Fuel Prices
Waking Up And Still Seeing My Car Parked Outside
Girls...... (hmm)
:D
Edited by AFTDRK
finding $20 in ur pants pocket u forgot u had.. yeah boy!
^^^ comparing how much u can fit in ur ass and being proud of it.. hmm sounds pretty gay, just saying :huh:
Edited by steveP
Watching Cash Cab, the blokes in the cab needed to use a shout out, deciding who to ask about some music question.
Driver 'We'll pull into this servo, there's a girl here you can ask?'
Passenger 1 'Nah she doesn't look like she'd know'
Passenger 2 'She drives a holden she must be bogan!'
Made me smile.
It was torture when i was interstate and i had to settle for stupid crappy oak chocolate milk!
Yes I feel your pain!!Should see my face light up when I find a servo here in Sydney that has Iced Coffee the "real stuff" :huh: Liquid Gold!!!
What makes me happy:
My car
My Gorgeous Boyfriend
Doing nice things to make others happy
Racing on the track
Finding car parts to buy that are uber cheap
Alcohol
Riding my bikes thru the hills. Nothing but me, the bike and some windy roads.
That sounds suspiciously like a certain ad I saw advertising cigarettes.... or was it condoms? heh
Ruby... the Marlboro RoughRider Man
-D
f**k yes!
giving the clutch a jab with a quick handful on the bike :woot:
working on my bike/car
not working on my bike/car (completely over fixing things atm)
dropping the clutch
women!! lots of them
boobies
all my friends
going out
alcomahol
people who just come up to me and start talking (im shy)
+1
meeting new people
having a good time
hills runs when stressed... no better cure.
iced coffee
and hot fatty food after a night of heavy drinking :)
Edited by tx3_90
watching my aquarium
daily iced coffee hit
my GF (sometimes) :O jk
driving something RB powered
redtube +1 vu :wub:
beer/beam with mates at the local.
also enjoy this forum when people relax and look at the lighter
side of things :D
Edited by craig R33
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
