As per topic- bringing my car back to standard and looking for some s2 injectors (s1 may well be exactly the same?). Have Nismo 555cc's if somebody is interested in swapping with cash my way.
The nismo's have only travelled 20,000kms.
Price
Nismo's on their own: $650
Nismo's if stock injectors provided: $500
If somebody is interested in just providing the stock injectors then please PM the price you're after.
I know this is technically in the wrong section as I am looking for stock injectors but given I am selling the Nismo's here I think its justified as this may save someone money as they don't need their stock injectors once Nismo's are installed.
Contact details: 0407 766 805 or via PM.
Edited by nfi
i maybe interested in a swap. i'd be looking at more so a swap plus 400 your way.
i have some rb25 s1 that are in my engine atm... might be interested in an upgrade.
where are you located
what kind of power are these items rated to in a rb25?
i have some in my rb20 at the moment, but my rb25 will soon be replacing that.
