the bilsteins are circlip height adjustable, its not as easy as threaded sleeve adjustment, but fine if u dont plan on changing height all the time. you can however put threaded sleeves on the bilsteins to make it easily height adjustable like any other coilover package.
well, after having a look over coilovers prices, I would include any dampers into the list again.
that damn japanese yen is not getting any lower, everyday it's higher and fkin drier :D
currency exchange rates kills me. difference in prices around %30-35 increased!!
is it possible to use my Teins' springs and fit them on a set of different brand shocks?
or, maybe someone here have a second hand set of coilovers and wants to sell it!!
cheers.
Anyone know what is the optimum ride height for the Greddy Type S and Bilstein with Eibach springs for the R34GTT? Don't wish for it to be too low because my ride has a full bodykit that's scrapping half the town humps.
hey mate,
would you please tell me waht springs rate you have on those monoflex? and how is the ride on pumpy streets?
how long you have them on your GTS?
The spring rate is 8kg front and 6kg in the rear. We have had the shocks revavled by Graham and Mike at Fulcrum Suspension in BRisbane to suit what we do. The car is basically a track car (half caged, stripped weight etc etc).
With the higher spring rate than the super street, on the track we found a few issues with understeer etc. A few swaybar adjustments, shock adjustment and different wheel alignment specs fixed the issued....mind you it took a while for it all to 'come together' again as we were very used to the super street...so it was much a learning curve.
As for what its like on the road....its firm. However with the shock absorbers set towards the softer end of adjustment the drive on the road is quite bearable and the smaller bumps tend to have the harshness taken off it if that makes sense.
If you want to know anything more, just let me know. Happy to help where i can.
The springs will probably be a straight up 2.5" ID spring....so it will fit on any other coilover that uses a 2.5" spring. However, the free height of the spring, and even the rate may be a problem (it may not to).
Those springs wont suit standard, or standard replacement shock absorbers (KYB ETC).
I wish we have a track :)
so the monoflex isn't the best choice for what I'm planning to do, since it's not comfortable on streets, and I won't have the chance to hit any track.
choices are narrowed to Bilstein, Tein Super Street, and HKS Drag (found a used set for sale)
I'll be searching for info about the HKS Drag set, however, your feedback is most welcome :(
cheers,
Super Street. Have been in an R32 GTR with them and R33 GTS25T with them. Ride was sporty and compliant. And i dont believe the Teins will be durable as the Bilsteins but youl will still get an easy 50,000-80,000kms out of them based on the kms i have seen people getting from them
Honestly, after checking all of the choices and prices, the best as I can imagine would be as what Todd replied here in this topic, Bilsteins & Eibach.
I tried to locate some dealers for the bilsteins, but it’s too hard to find a dealer who sells Skylines’ Bilsteins. I found some vendors couple of days ago, but their prices are too much.
50,000 to 80,000 kms is reasonable, isn’t it !!
hey mate,
I would really appreciate a clarification about the difference between the twin tube and the monotube. which one is better, and used for which type of driving.
hello,
if Bilstein is not hight adjustable, then it's out of my list. is the set you have hight adjustable?
Circlip grooved height adj. 2 hrs to adj. height but as with any height adj. gear you will need to do an alignment when you change the set height.
Had mine at 308mm frnt.
going back to 350mm fr, 340mm rr seems to be the best when its there
Nascar use Bilstein, Nissan sell an upgrade susp. pack for 350z range which is also Bilstein-they maynot be the absolute best but they dont cost $50K either so for the cost as to performance I am extremely happy with them- best Ive had so far, had KYB,KONI, & various others and the Bilsteins blow them all away- German Engineering FTMFW
Also being in Middle East you are closer to the Bilstein Factory than we are so contact them directly, You may not have the pollution prob's of Japan so Valves and rubbers will last you a considerably longer time.
HKS will be like Tein- where to service will be a prob for you
Australia is just like everywhere else, when the stocks run out we have to wait for the parent company to dispatch more to here via quota- ie we wait till Bilstein can sell enough to justify the shipment
my 2c
my 2c
I did check the Bilstein website few days ago, it seems that they don't have GTR shocks at the mean time (as the message on their website indicates). however, no harm to contact them. I'll try to call them and check again, maybe they can supply some shocks in reasonable time.
I'll see how it goes, it's eaither the Bilsteins, or the Super Street Teins. I'll let you know guys :blink:
thanks a lot for sharing all openions and information, greatly appreciated.
cheers.
latest update, I got a good deal on a new Tein Super Street kit from Amber Performance. I found them on ebay.
I bought that kit and it should be in the way.
I'll let you know how it goes when I fit it to my car.
cheers.
Edited by evil angel
cheers.
Will keep my eye on this thread for your reply, am interested to see what you think of them :D
  • 4 weeks later...
Will keep my eye on this thread for your reply, am interested to see what you think of them :blink:
Hi,
sorry for being late, I did fit the kit to my GTR. I did some drive test on various streets to see how those coilovers respond.
I got them lowered to the end in three corners, the rear right corner will get lower than the rest if it's lowered to the end, I don't know why, maybe it's something in my car !!! or it's common in all BNR32 with those coilovers !!! I'm not sure. anyway, I couldn't do a 100% accurate measurement to all corners height, it was done using a regular foot measurement tool.
regarding height of the car, you won't be able to completely drop it to the ground, but it's more than enough for normal street use. if it's lower than that, I might suffer when facing any speed control pump on the road. furthermore, I like how my car looks on that height level.
I've tested the drive on different street condition, and different speeds. in all cases, the drive was really comfortable with very minor bouncing comparing with other stiff coilovers.
on normal streets, when I go on relatively normal speed, say 75 - 80 km, drive is smooth with nothing to mark. if I exceed that speed to more than 95 km, drive still smooth, but when I hit a pumpy spot on the road, or to be more specific, when there is a big sharp difference in road height, the front tires slightly touch the inner fender covers. however, I haven't had the chance to play with the damping force level yet. I think it might make a difference on other damping level.
on highways, I reached a speed of 195 km and the drive is comfortable and stable.
body rollover. the old kit I've removed was stiffer, so now I have some body rollover. not like the OEM dampers, but its there. however, as I mentioned, damping force still untouched. and I don't know what damping level I have now. it's because I had a water leak underneath the intake manifold and I had to take my car to the workshop and get it fixed. that thing had interrupted the testing process :happy:
nowadays, I'm taking the car again to the workshop to complete the project and put the rest of the parts. going serious with the GTK 850 turbo, full modified fuel system, AEM EMS,,, etc.
when I have the chance to play with the damping force, I'll let you know.
hey mate, on a 32GTR you don't want to go lower than ~350mm front and rear or the drive shaft angles end up crap.
this measurement is taken from the centre of the wheel to the outer guard (i.e. vertically directly up from the centre of each wheel, to the guard)
hi buddy,
I'll check the distance from the center of the wheel's center cap to the outer guard. but just to make sure, by saying the outer guard, you mean the fender's bow line above the tires (finder lip), right?
cheers
hi buddy,
cheers
yep, that's right
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
