Yeah R32 GTS-T look better without the spoiler.
I always wanted the spoiler on my GTR but it did not come with it and it looks just as good.
To patch up the holes, you could use the rubber plugs or gromets, whatever ppl call them, or take it to the panel beater and get them to weld metal in the patch the hole and re paint the boot lid.
https://www.sau.com.au/forums/topic/247490-spoilers/#findComment-4297342
I can never decide.. I like it with or without a wing... each gives it it's own look.
currently Mine is without a wing.
But it does need to be a GTR wing if you keep a wing on. I hate the GTST wings..
here is the car with the wing on..
https://www.sau.com.au/forums/topic/247490-spoilers/#findComment-4297469
I can never decide.. I like it with or without a wing... each gives it it's only look.
currently Mine is without a wing..
You sure have a sexy car there. i like without the wing. looks so smooooth.
u going on the skyline cruise on the 14th?
https://www.sau.com.au/forums/topic/247490-spoilers/#findComment-4297697
thanks ;)
skyline cruise? i takeit this isnt in QLD? if that's the case, then no I won't be able to make it ;)
ya, qld. meeting at mudgee and springwood.
u should be able to find it. go qld, events and its like the first one. cos i left reply lol....
hang on..........................
http://www.skylinesaustralia.com/forums/Sk...08-t239240.html
https://www.sau.com.au/forums/topic/247490-spoilers/#findComment-4297751
the r32 gtst spoilers look ugly
It looks better without it
But i believe they look even better with a gtr spoiler and since its not a GTR no spoiler is the only option.
I would get the boot patched up and resprayed. The rubber plugs will be good for protection against rain etc but it does look tacky.
https://www.sau.com.au/forums/topic/247490-spoilers/#findComment-4297915
Heaps better without it. Any spoiler on a gtst looks shit i think. Even gtr spoliers. gtr spoilers only look good with the gtr's wide guards and on cars with kits like sl!ms. Definately weld up the holes, i have white tape over mine but ill weld them up soon.
Mine:
https://www.sau.com.au/forums/topic/247490-spoilers/#findComment-4298066
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
