Brent was excellent.
I tested the water with Nengun by first purchasing a brand new profec B boost controler. It arrived swiftly in a package that had not been opened - brand new.
I then bought a powerfc + commander and had the same brilliant result.
do a search on the forum on "nengun" and you'll find all the reviews/comments etc.
Apparently his email gets over full and emails go missing. If you dont hear from him, send him another.
Mark
deffinately pm nengun on this forum usually replies straight away if not next day, i have just orded a hks i/c kit havnt recieved it yet as i only orded it 15 mins ago, but seems like a very nice guy and will most certainly be doing business with him again
Hippy: down SYDNEY custom clearance warehouse. You do need to pay import duties. I believe it's attract 10-15%, depending on what the items is.
Dvs-8or: Brent will give you the items in AU$, so that you know exactly what you paying for....
NO doubt that Brent is the MAN, great doing business with NENGUN.
Every time i try to veiw this site, i get the following:
"The page you are looking for is currently unavailable. The Web site might be experiencing technical difficulties, or you may need to adjust your browser settings."
What do i need to do? Please help
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
    • Just one thing; tapping tapered threads is tricky. Taps are always tapered and you would generally run it as far as you can, but with a tapered thread you have to stop much sooner otherwise the wide part of the taper will run in too far and you will have to thread the sensor in too far too as well (possible that it will never make a good seal) BTW nice wide wheels, I guess the top one is for the back!
