Brent was excellent.
I tested the water with Nengun by first purchasing a brand new profec B boost controler. It arrived swiftly in a package that had not been opened - brand new.
I then bought a powerfc + commander and had the same brilliant result.
do a search on the forum on "nengun" and you'll find all the reviews/comments etc.
Apparently his email gets over full and emails go missing. If you dont hear from him, send him another.
Mark
deffinately pm nengun on this forum usually replies straight away if not next day, i have just orded a hks i/c kit havnt recieved it yet as i only orded it 15 mins ago, but seems like a very nice guy and will most certainly be doing business with him again
Hippy: down SYDNEY custom clearance warehouse. You do need to pay import duties. I believe it's attract 10-15%, depending on what the items is.
Dvs-8or: Brent will give you the items in AU$, so that you know exactly what you paying for....
NO doubt that Brent is the MAN, great doing business with NENGUN.
Every time i try to veiw this site, i get the following:
"The page you are looking for is currently unavailable. The Web site might be experiencing technical difficulties, or you may need to adjust your browser settings."
What do i need to do? Please help
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
