hey guys just a quick question, i have looked at a few post about adjusting the rear camber but havn't found a simple answer.
i have just lowered my r32 and have been told its good to get wheel alignment everytime you lower your car as it can camber out a lot.
my question is, can i get away with JUST installing an adjustable upper rear camber arm, or just a lower rear camber arm, or will i need to use both?
thanks.
https://www.sau.com.au/forums/topic/247682-rear-camber-agjustments/
oh ok cool, but will i need both upper and lower camber adjustment arms? or either one?
You are getting the terms mixed up.
Have a look at the attachment. It shows an exploded diagram of the rear suspension.
You will see there is a lower arm and two upper links - a front & a rear.
Ignore the lower link it does not get altered as part of a camber adjustment.
To adjust things more than standard you need a camber adjustment kit (or two) that adjusts both the front & rear upper links. One kit does the inside bushes. A second kit does the outside ones but is only needed if you want yet more adjustment. From memory (not reliable) it is about 0.75 degrees per kit.
If you just get a replacement upper rear link (the link, not the bushes) you can fix the camber issue but add in a whole heap of bump steer. Which is what BNR32 is saying.
rear.PDF
Edited by djr81
you may not need either. there is factory rear camber adjustment. just not much of it. try that first. if you still need more adjustment buy upper control arms and traction rods. that will enable you to adjust camber. no you don't need to also get the lower control arms.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
