Hi all.
Was just wondering if it's possible to fit a second amp under the passenger seat in my 33, there's lots of bumps and stuff under there and I'm rather dubious.... I've got one amp under the driver seat already, but want to leave it there, bridge it's channels to the fronts and then put in a second amp to run 2x 10's.
In particular, I'm looking at this amp in bridged mode to run the 10's.
Is it possible? If not, where are others putting second amps? I like my audio gear to be neatly hidden from sight, and I can't just sit an amp on the boot floor anyway, as I go to the track and also need to fit a large guitar amp in there (my sub enclosure is installed in such a way it can be removed/re-installed quickly).
Edited by sl33py
Hi all.
I've got two amps and lots of other goodies in the little compartment behind the rear seat... i.e. next to the battery and above the fuel-pump cover. Out of sight, doesn't take up any room (well, not that wasn't just wasted anyway), and wiring is fantastic (power direct from the battery, rear-speakers and sub are very close, just had to run new front speaker wires and in your case, RCA's to the HU).
I'm running a 'CarPuter' in there too, so I didn't need to run RCAs all the way up to the front of the car (had to run VGA and USB cables for the touch-screen instead :(), but I think it's a fantastic little spot for amps and other gear.
Interesting. Musta made it fun to tune the gain and crossovers :( I'll have a looksee tonight
Haha yeah it was a bit of a job... but I'm lucky coz the amps in the 'line have raised knobs for the tuning, you could just reach in and turn them as required. The one in the Lancer has kinda 'screw' ones u need a screwdriver to adjust... that would have made things pretty much impossible lol!
+1 for area behind rear seats
i made a bracket to hang down from the computer for the demister etc or whatever it does, so it just bolts on and hangs off that so I can take it off if one day i decide i want a different amp or something :P
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
