Hey I'm selling all my performance gear as my car is for sale. All parts were on my car in working order, made 312rwkw at 20psi with these bits bolted on. I also have some new parts for sale which were never fitted. I'm happy to sell parts seperately or as a package and can send interstate. Some prices are negotiable, don't hesitate to ask.
Garrett GT3540 0.82 rear full psi @ 4500rpm approx 10,000km old in car for 3years excellent condition. Laggy down low but up high pulled like a train. Comes with cooling lines except one water line which I unfortunately damaged. :) I'll thorw in a turbo bag aswell. $1,300
post-427-1228822011_thumb.jpg post-427-1228822345_thumb.jpg post-427-1228822410_thumb.jpgpost-427-1228822449_thumb.jpg post-427-1228825696_thumb.jpg post-427-1228825741_thumb.jpg
GCG Stainless Steel High mount exh. manifold cost around $1100 at the time of purchase, when there was hardly any copy units around. The last runner had to be modified to allow the dump pipe to fit. $400
PSR 50mm external wastegate very good condition. Comes with screamer pipe $350
Custom dump & front pipe with flange for plumbing in wastegate pipe. $200
Greddy Plenum comes with std. throttle body adapter plate(never fitted used Q45 t/body) fitted to car for 2 years excellent condition. $700
Nissan Q45 89mm Throttle Body good condition. $250
Denso 660cc top feed high impedence injectors very good condition $500
Custom Fuel rail in anodised blue not sure of brand, purchased thru VPW about 1 year old. $200
Powerflow injections custom top feed fuel rail for rb25det. Upgraded to the blue anodised rail purely for looks $150
Malpassi Fuel pressure reg $100
Trust Oil Cooler & Relocation kit very good condition 2 years old $600
Following items are brand new.......
Mickey Thompson ET Street radials 255/50/16 x 2 on 300zx rims $500
post-427-1228826052_thumb.jpgpost-427-1228826079_thumb.jpg post-427-1228826112_thumb.jpg
Nismo Engine & G/box mounts to suit Rb25det $500 for the lot.
Greddy Breather Tank $150
Braided turbo cooling line kit purchased from horsepowerinabox.com, never got around to fitting it $200
misc. items....
RB26 Timing & Coil pack covers $150
Gktech Dump pipe suit R33 Gtst $50
please pm if interested
cheers
https://www.sau.com.au/forums/topic/248334-r33-gtst-performance-parts/
why did you remove all this stuff mate? stock motor?
Interested in the gate. Any chance of knowing what the lowest boost you could run with the gate was?
I'm selling my car. I've put it back to stock.
UPDATE:
Turbo kit may be sold that is: turbo, turbo bag, manifold, gate, braided lines, dump & front pipe and fuel reg...
So these items will not be seperated pending sale.
Greddy Manifold and Q45 throttle body pending.
GKtech Dump pending sale
Cheers
Edited by JET-RB
i will take the turbo mainfold if its not already gone.
please let me know asap
regards, Jack
Edited by Mr. Untouchable
Update:
Turbo, exh. manifold, gate, dump, braided lines, plenum, throttle body, injectors, blue fuel rail and reg are sold pending payment.
Nismo mounts and Oil cooler kit pending sale
dano4127 - sorry bud just what I got pictured.
cheers,
Mo
All items are available again. Got stuffed around with the turbo and intake parts.
To any potential buyers please make sure you got the funds before agreeing to purchase, just makes life a lot
easier... :P
Cheers
so both fuel rails (which take top feed injectors) can be adapted to normal r33 rb25det (side fed) ? very interetsed in the silver one :(
If you mean will it bolt on to the standard manifold, yes. Obviously you have to use top feed inj. not side feed. The silver one is available.
Update:
Injectors, rail, fuel reg, Q45 throttle body and New turbo lines SOLD
The following items are still available:
Turbo
Front and Dump pipe
Oil cooler kit (btw has an internal thermostat core size h14cm x w30cm)
wheels & tyres
psr wastegate
Nismo mounts
breather tank
rb26 engine covers
If you're interested, I'm negotiable on prices. pm me for further inquiries.
cheers
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
