Hey guys,
The PGA-SA Interclub Dyno Day is on once again! Topic from previous day can be found here:-
http://www.skylinesaustralia.com/forums/Pg...ay-t225222.html
Just trying to get the word out to all the clubs. Last 2 days were a reasonable success, and a number of you bloke rocked up last year to show off some pretty tidy machines, and put out some pretty impressive numbers, which was awesome to see! The turn outs have been pretty good, but this year we want to make it huge! We had and do have a number of sponsors for the event, and hence prizes & awards on the day. There is also talk of a 50 entrant extended day, and a show & shine on the primary school oval adjacent GWW, but confirmation is yet to come.
Link to official webpage, is below:
http://www.dynoday.info/
Link to thread on our site, is below:
http://forum.pulsar.org.au/showthread.php?...454#post1549454
Hope to see some more of you guys attending or entering once again!!
Cheers,
Rick.
  • Replies 305
Yeah.. it was actually posted up, and in full swing back in october. I've just been a bit lazy with promoting, and I thought it had already been done here on SAU by another member of the PGA club. He had posted up about it, like 3 days after the last one was over.. :D
The reasoning for that was because he had planned ot have it earlier in the year on a permanent basis, starting by kicking right off with next year to begin with! The only thing is, because this one ended up so late in the year, and because the next is ending up so early in the year, they have become real close together.. :P
But don't be fooled... we promise a fantastic day will ensue! :)
Rick.
  • 4 weeks later...
so is there any more updates on this
i went down to graham west workshops last week to get some work done
and enquired about this
they confirmed it but dont know when they will start taking payments
more infor please
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
