  • Replies 305
well i am really going in this event to see what it makes after tuning and 5psi increase
last time i was there 7psi made 179rwkw
so really i am using graham west dynos as my baseline dyno
So is there anyway we can know before the day what times our runs are?
i know this starts at 8 and i will try to get there before then but just wondering if
there is someway of knowing when my run is thats all
Definately! The times will be released the Thursday prior to the day, or sooner if the field becomes fully subscribed (as it looks it may be!)
just about to call up and enter. way to knackered to drive out there and pay...
... and im entered. yay.
krish/ben/nene/damo/other northies attending, feel like cruising in as a group?
Edited by scandyflick
well this event does start at 8 so if you want we could all group up at parafield gardens bunnings at lets say 7am
i will be more then happy to cruise from there to graham west workshops
its not that bad of a drive dave
should be good one let me know if you want to organise something on those lines there dave
ALL SPONSORS FINALISED!!!!
Dyno King: Sponsored by Adelaide Tyre Power
Evo v Rex Challenge: Sponsored by S&J Performance
Rotary shootout: Sponsored by REVS
RB v JZ Challenge: Sponsored by Phillcom Rally
Most Powerful Pulsar: Sponsored by Graham West Workshops
Little Battler: Sponsored by Pro Wash Golden Grove
There are other categories, but these are the main ones that will have prizes.
The event will be covered by: www.custom-cars-online.com
Cheers!
Daniel.
thats a really good list of sponsors you got there daniel
well done on the awesome job you guys do in organising these dyno days
very well organised and well run
Cheers mate! I'm just waiting on Jason from REVS to send me his logo, and then I'll show everyone the poster!
www.dynoday.info has been updated too!
you should put the Dyno Day website in your signature
>>>Register NOW!! only 10 spots left<<<
[center][url="http://www.dynoday.info/"][img=http://www.dynoday.info/images/DynoDaylogo.jpg][/url][/center][url="http://www.dynoday.info/"][center][color="#FF0000"][b][size="2"]>>>Register NOW!! only 10 spots left<<<[/size][/b][/color][/center][/url]
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
