I did a search for similar topics.. but nothing that matched my topic.
Ok guys, this is what has happened. It was super hot day the other day, i noticed my oil pressure gauge drop as though i had no oil pressure. so i pulled over and the tappets where ticking etc as though there was no oil. The engine seemed super hot. Checked the oil, the gauge said there was plenty of oil, and when i held the throttle on the oil pressure picked up to 40psi.. then drop off when i stopped at the lights. so i switched the car off at all the lights and the car got me home.
The next morning, the oil level was full, but.. i had no radiator fluid.. there was a hole in the bottom.. and the water was flowing out as quick as i was pouring it in. so.. that explains the super hot engine.
Now.. the oil was pissing out of the rocker cover.. causing lots of smoke out of the engine bay, so i bought a new kit and replaced it. i did notice that i was undoing the screw down bolts with my fingers.. so that explains the oil pissing out over the exhaust, and i'm hoping the dropping oil pressure. When i started the car in the morning.. cold.. the oil pressure held at 40psi with no sign's of dropping, though i think it need's to be 60psi at cold idle.
So.. i just did a compression check the engine cold.. and i got
1... 160psi
2... 160psi
3... 145psi
4... 130psi
5... 150psi
6... 150psi
I don't believe the head gasket has gone.. but it does seem the piston rings on the 3rd and 4th cylinder's are on their merry way.
Q1, with the rocker cover gasket's no being secured down and not sealing correctly.. will that drop the oil pressure?
Q2, will it hurt my engine with such a compression variation?
Q3, is their another method of checking for a blown head gasket? remember there is no water in the cooling system.. i need to get a new radiator.
https://www.sau.com.au/forums/topic/248746-rb20det-compression-test-results/
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
