  • Replies 47
Posted Images
The only real benefit with stainless steel is it's resistance to Corrosion meaning it will last longer and it's stronger....Flow characteristics would be very simular, if not exactly the same as an identical mild steel system.
Edited by Ryanrb25
its in the way the ceramic inner to the cat has been made will flow more than a normal cat that is all nothing special in the steel only that it ISN'T Chinese its Aussie blue steel and or sometimes from NZ
Looks the goods!! Beleive he did some work for Simon as well and that was a great sounding exhuast!
2x2.5 inch pipes is going to flow more then 1x 3inch?? Or so you'd think (5inches of pipe compared to 3 inches makes a big difference)
Personally i'd rather keep the cat and loose a little bit of performance and not cop the massive fine for not running a cat but thats just my opinion
Not quite - area = pi*r^2, so:
3" pipe = 4,560mm2
2x2.25" = 5,130mm2
2x2.5" = 6,333mm2
5" pipe = 12,667mm2
so as you can see, 2x2.5 is definately not as much area (flow) as a 5" pipe by a long shot
^Not necessarily. There has been a fair bit of research (well particularly for V8s) and I think the results concluded there was VERY little difference between twin pipes and singles, and if anything a single was maybe 1-2% better flow from memory.
This is due to the single having less swirling restriction from memory, however for now I can't find the evidence to backup my claims.....
    • Kinda glad I never got to this ..    https://www.facebook.com/groups/1483859159195077
    • @GTSBoy This method was able to get readings of -10 to -2, so it looks like its monitoring.  Now I need to figure out why the vacuum on the line provided isn't alternating with manifold pressure.  I went with 2 lines that an RB25 tuner recommended but I'll get a longer hose and try directly off the back of the manifold.  He may have been used to OEM intake setups while I have a DBW setup that removed the MAF and IACV.
    • I work at a car detailing and tinting shop called Quark which gets all manner of German cars in usually (mainly due to a contract with Mercedes Benz Kita Osaka, BMW Nishinomiya and others) but every once in a while something special comes in, like a fully restored 1972 HS30 Nissan Fairlady 240ZG... The shop owner had immediately started applying film to the windows as soon as it was in the shop so the interior was completely covered in towels and plastic sheets. But I could get a few photos of the engine bay which was restored like new. Such an amazing car to see in pristine condition in Japan these days.
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
