Well title says it all....I used to read this mag a while back, have been into various newsagents over the past few months to buy a copy but it seems that no ones has it and from what I can tell the whole mag seems to have gone down the tube...
Anyone know anything, like if it is truly dead (and if so, how come?) or any other info...Links to news stories or anything would be tops...
Cheers
https://www.sau.com.au/forums/topic/248985-speed-magazinewhat-happened/
Speed has been gone for ages, couple of years I think.
Correct. Towards the end of it's time, it was turning into quite a n OK read, but someone pulled the plug. Too soon, IMHO. It always has qual' photos, and even ran a shot of my car that came out trumps, even with a tough caption!
SP33D mag got buried because the publishers couldn't justify it. I think they were trying to aim it as a classier Autosalon mag with same great photography, reasonably well sorted cars, basic technical articles, but no skanks.
Unfortunately I think that the other ricer mags in the publisher's stable made the cut. Half dressed pre-teens draped all over candy painted cars sells magazines.
I didn't mind SP33D, and actually bought a fair few issues. It was less ricey and VD-ridden than Hot4s / AutoSalon / Freestyle etc but a lot lighter and more visually appealing than Zoom etc. For me, if they'd gotten their facts right more often and used a spell checker it would have been the perfect general "tuner" mag.
Yeah I agree with you on that one.
The articals were actually quite helpfull and the cars were actually decent, non of that hot 4's showpony bullshit.
I got the issues 1 to 4 and then was given issue 16 from memory, again was a good read with some helpfull tips.
Other than that I read HPI but I find they just give an over all / general idea of the cars and modifications.
That was 3 years ago, if not more...
Im pretty certain the last issue made had the SAU-Vic GOR Cruise featured in it... was 4 years now i think about it because my car was in it... and its been off the road for the past 3 years
Yep, died in '05 from memory. I should know though, my car was in the last issue :P
I have that issue, I recall I bought it for the write up on your car :D
Grab a copy of Tarmac magazine, only thing I buy nowadays... other than the odd copy of UK Top Gear mag
AWWWW wish I could say my car has been in a mag. lol.
but noooo.
I WISH!!!!! I WOULD SOOO LOVE IT.
lol
and now featuring a stock R32 and its performance is pretty darn.... ahh stock?
lol but it looks good.
Suppose it could be a "how stock can ya go" featured car...
like a limbo type context..
Or, just plain old "HOW TO BEAT THEM DEFECTS." lol
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
