Wtb R32 Gts Parts In Vic Seats Brakes Exhaust Afm
wanted for R32
front and rear brakes including rotors calipers flex lines 5 stud turbo (hard lines to master on front would be nice)
driver and passenger door trims black
indicator stalk and cover
steering wheel
driver and passenger door seals
passenger side front guard
4 caster tops from front and rear shocks, a set of standard shocks will do
2 front headlights
2 tail lights
2 front indicators
std rb20det AFM
front drivers seat black cloth
rear 2 peice seat
full exhaust from turbo (std or aftermarket)
not looking for anything brand new, gtr spec or custom just some left over stuff you may have laying around
PM as i will check here offen
will to pickup in victoria but am traveling to goldcoast during christmas break
thx
ok heres the list of pretty much everything i need
i just got a R32 missing alotta parts
brakes
front and rear calipers rotors nuts/bolts pads and the tin cover for 5stud turbo
solid front lines from booster and flex lines
solid rear brake lines (just the small section from the booster to the alloy block about 100mm long)
drivers seat
rear 2 piece seat
passenger side guard
passenger side metal door catch
drivers side electric window mechanism
both front door trims (bare)
front lights and indicators
tail lights and reverse lights
full exhaust (std or aftermarket) turbo back
passenger side and center dash vent
cluster and surround
heater control box and surround
indicator stalk
steering wheel and boss
RB20Det air flow meter
std airbox/pod
and the 4 caster tops from the suspension (crazy i know)
pm me with what ya got and what ya want for them
im in S.E suburbs
I've got a full set of R32 GTR brakes if you're interested. I have a thread on here about it. Let me know if interested.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
