Well it seems that at my last outing to winton raceway my turbos decided that enough was enough.
so im now looking to upgrade a bit. the thing that im having trouble deciding weather to stick with the twins setup or to go big single...
if its going to be twins, im looking at the garret 2860-7's.
i want something that going to give me good power/torque, without sacrificing response. the car does see a bit of track work...
but ive always liked the idea of the single turbo with the external gate screamer (love the noise!!!).
has anyone got any suggestions on what i can go for?
cheers.
matty.
https://www.sau.com.au/forums/topic/249121-hmm-what-to-do/
You know what, i was gonna go for the HKS gt-ss kit but with all the trouble from EPA today its best to for for garrett stuff because if you do wind up in a testing booth, they will only see the garrett logo and think its stock.
everyone so far is saying the -7's are the bomb for track and street + add some cams for a little extra top end and your there.
I wanted a big single sooooo badly for the gate and look but honestly, after my recent exhaust EPA im sick to death of dealing with all the bullshit so stick to the lowmounts.
https://www.sau.com.au/forums/topic/249121-hmm-what-to-do/#findComment-4321588
Ummm have you even looked @ GT-SS turbos?
They only have Garrett markings on them, Garrett housings etc.
Fact. Ive seen them, i have them.
Either way, GT-SS are not affordable anymore with the yen the way it is.
-7's all the way. You don't need cams.
https://www.sau.com.au/forums/topic/249121-hmm-what-to-do/#findComment-4321684
so it looks like im on the money then. :(
its currently got the N1's on it, with 20 psi of boost the car made 310kw at the rears. what sort of power should i expect to se out of the 2860-7's with similar or less boost?
a bit of a curley one i know but im just after a ball park figure. im hoping for about 350kw (bearing in mind im getting larger injectors done at the same time.). do you think im dreaming, and what size injectors should i go for?
cheers.
https://www.sau.com.au/forums/topic/249121-hmm-what-to-do/#findComment-4322168
near enough to the same really, GT-SS make around 330rwkw or so.
Depends on the dyno more than anything.
The -5's (next step up) will make 350, but they are good for a bit more, but then you hurt response so thats where the question lies
https://www.sau.com.au/forums/topic/249121-hmm-what-to-do/#findComment-4322354
it seems the that -7's are the go,
would 700cc injectors sufice, or would i need bigger?
also is it worth spending the extra money on cams as well, or will the good ol' standards do the job?
700cc is fine, and standard cams will work a treat ;)
https://www.sau.com.au/forums/topic/249121-hmm-what-to-do/#findComment-4323083
NA - Not Applicable! :bunny:
As for you conrad... i suggest rather than buying really expensive STI parts to make your car something its not, just get the genuine article. or at least get a real car... you can only abuse an "STI enhanced" badge so much! :bunny:
https://www.sau.com.au/forums/topic/249121-hmm-what-to-do/#findComment-4324327
Shepo - I would have brought an STi, but the bank was being a complete tightass that day!! And "Expensive" parts?? That's what I have you for!!! Full retail is for chumps... And who needs an STi motor... I have my SHARPIE TUNE to take care of that department!!!
But then again. Whose car is running...? Hmmmm?
Edited by theDOG
https://www.sau.com.au/forums/topic/249121-hmm-what-to-do/#findComment-4324605
  • 3 weeks later...
Just thought i would update for those who may be interested.
im going ahead with the 2860-7 turbo's. also sard 800cc injectors (probrobly overkill, but better safe than sorry in my opinion.) and lastley getting a trust stainless steel intake piping kit.
once done, should be good for a bit more power. :P
will keep you all posted as things progress along. let me know your thoughts.
cheers,
matty.
https://www.sau.com.au/forums/topic/249121-hmm-what-to-do/#findComment-4352916
cheers,
matty.
my thought on getting 800cc injectors: :P
https://www.sau.com.au/forums/topic/249121-hmm-what-to-do/#findComment-4352946
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
