Nah don't waste $20 a plug on those, they are designed to last 100,000km's (as most import drivers service every 5000km not worth it). Get a colder range plug which helps prevent breakdown if running more boost
I personally used NGK BKR7E's or if you can't get these just get BKR6E's
Remember to regap em to .8mm and your all sweet
Cheers
Edited by Weapon
https://www.sau.com.au/forums/topic/249280-sparks-plugs/#findComment-4330894
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
